today's work
    • 3724
    #2506
    Simply WOW. Thank you for explaining that to me.
      • 13897
      #2507
        • 3643
        #2508
        Shaftless SubDriver (SSD)
          • 13897
          #2509
            • 13897
            #2510
            • Ken_NJ
              • Sep 2014
              • 1001
              #2511
              I'm paranoid about running my boats in lakes around here that you just about cannot see the boat once it's under. Give me Groton. Give me Cohutta.
                • 13897
                #2512
                Give me a break... you pussy! Go deep or get out!
                The Horrible
                  • 13897
                  #2513
                    Hi David,
                    I hope your not upset that I jumped in on your build forum! I have a question that I am sure you could give me some advice on!
Name:	GREAT WHITE SHARK 23.jpg
                    I do not know if you have seen my build blog on the shark build!? Anyhow can you tell me where the prop should be located inside the shroud, and what distance the prop blade would be from the interior wall of the shroud?
                    I am new at this thruster building, and I am not sure of my design.
                    Thank you very much for your advice and knowledge!
                    "Firemen can stand the heat."
                      • 13897
                      #2515
                      Hi David,
                      Click image for larger version  Name:	GREAT WHITE SHARK 23.jpg Views:	1 Size:	50.3 KB ID:	183565
                      No problem at all, Rob. You want as tight a non-interference gap between blade tip and shroud you can get away with. The shroud is there to reduce 'tip losses' -- rule of thumb is to put the propeller disc in the center of the shroud.
                        Thank you very much David!
                        I really appreciate you taking the time to explain the correct method for installing the prop inside the thruster housing, and all those fantastic photos you posted up. Your photos, like they say, are worth a thousand words!
                        Once again you have come to my rescue...:-)) Thank you sir!
                          • 13897
                          #2517
                          My pleasure, Rob. Any time, my friend. Just passing on what others taught me.
                            • 1628
                            #2518
                            That Seaview build was a work of art, Dave.
                              • 13897
                              #2519
                              Thanks. A tough but rewarding job.
                                • 3643
                                #2520
                                Can you post a wiring diagram of your SAS/SNORT subdriver?
