today's work
    • 1113
    #2356
    Yes, but why is the U-Boot's stern blunt? Shouldn't it be of the knife-type?
    Jörg
      • 13996
      #2357
      I made this big-ass sanding block/board to level off the tops of the bulkheads and frames to the top of the hull proper. The anvil (Acme, of course) provides the weight so I get plenty of abrasive action when pulling and pushing the sanding block across the top of the egg-crate structure. I needed my other hand to hold the hull against sliding over the table.
      I'm helping Tom Harris assemble his big 1/48 Type-7 plastic model kit, which we're converting to r/c operation.
        • 13996
        #2358
          • 13996
          #2359
          • Davjacva
            • Nov 2022
            • 408
            #2360
            Jörg
            This is a Type IXC, not a IXD. IXD's were very narrow.
              • 1113
              #2361
              2nd last picture, the stern is flat and round. IMO there should be a sharp edge.
              E.g. REVELL:
              • ffr2608
                • Oct 2009
                • 347
                #2362
                Dave,
                More advice from the peanut gallery while you get real work done...
                Spray that thing with some Rhinoliner or other type of bedliner. I used white for the bilge in my 1:1 Ski Nautique and it is excellent...
                One and done...
                DH
                  • 13996
                  #2363
                  Originally posted by ffr2608
                  Dave,
                  One and done...
                  DH
                  Good tip, sir. Right now epoxy laminating resin will do -- I need a gluable surface for upcoming motor and other device foundations.
                    Maybe cut a window in the bow below the waterline as a port for a non waterproof camera for taking U/W shots. or would this be a potential leak point? Click image for larger version  Name:	images (6).jpg Views:	0 Size:	47.2 KB ID:	181861
                      • 13996
                      #2365
                      As this barge will only have an inch of draft, that won't work. This ain't the CALYPSO.
                        You could practically make that thing into an airboat... Click image for larger version  Name:	images (1) (10).jpg Views:	0 Size:	27.6 KB ID:	181866 Click image for larger version  Name:	z8mjicovp2oz.jpg Views:	0 Size:	58.9 KB ID:	181865
                          • 13996
                          #2367
                          I could practically make it a ****ing Rocketship; I could mount 300gW lasers on it and wipe the shoreline, cutting the entire membership of the Elite Fleet in half; I could grease it up and shove it.....
                            • 13996
                            #2368
                              Differential steering?
                                • 1113
                                #2370
