today's work
    • Oct 2017
    • 1029
    #2356
    Yes, but why is the U-Boot's stern blunt? Shouldn't it be of the knife-type?
    Jörg
      • 13867
      #2357
      I made this big-ass sanding block/board to level off the tops of the bulkheads and frames to the top of the hull proper. The anvil (Acme, of course) provides the weight so I get plenty of abrasive action when pulling and pushing the sanding block across the top of the egg-crate structure. I needed my other hand to hold the hull against sliding over the table.
      I'm helping Tom Harris assemble his big 1/48 Type-7 plastic model kit, which we're converting to r/c operation.
        • 13867
        #2358
          • 13867
          #2359
          • Davjacva
            • Nov 2022
            • 406
            #2360
            Jörg
            This is a Type IXC, not a IXD. IXD's were very narrow.
              • Oct 2017
              • 1029
              #2361
              2nd last picture, the stern is flat and round. IMO there should be a sharp edge.
              E.g. REVELL:
              • ffr2608
                • Oct 2009
                • 331
                #2362
                Dave,
                More advice from the peanut gallery while you get real work done...
                Spray that thing with some Rhinoliner or other type of bedliner. I used white for the bilge in my 1:1 Ski Nautique and it is excellent...
                One and done...
                DH
                  • 13867
                  #2363
                  Originally posted by ffr2608
                  Dave,
                  One and done...
                  DH
                  Good tip, sir. Right now epoxy laminating resin will do -- I need a gluable surface for upcoming motor and other device foundations.
                    • 3633
                    #2364
                    Maybe cut a window in the bow below the waterline as a port for a non waterproof camera for taking U/W shots. or would this be a potential leak point? Click image for larger version  Name:	images (6).jpg Views:	0 Size:	47.2 KB ID:	181861
                      • 13867
                      #2365
                      As this barge will only have an inch of draft, that won't work. This ain't the CALYPSO.
                        • 3633
                        #2366
                        You could practically make that thing into an airboat... Click image for larger version  Name:	images (1) (10).jpg Views:	0 Size:	27.6 KB ID:	181866 Click image for larger version  Name:	z8mjicovp2oz.jpg Views:	0 Size:	58.9 KB ID:	181865
                          • 13867
                          #2367
                          I could practically make it a ****ing Rocketship; I could mount 300gW lasers on it and wipe the shoreline, cutting the entire membership of the Elite Fleet in half; I could grease it up and shove it.....
                            • 13867
                            #2368
                              • 3633
                              #2369
                              Differential steering?
                                • Oct 2017
                                • 1029
                                #2370
