today's work
    #2311
    Originally posted by bwi 971
    Is that a coffin for the model-making craft?
    grtz,
    Bart, the poking SOB!
    LOL...
    ... THAT'S MY LINE, YOU DAMNED FOREIGNER!!!
    (Wish I had thought of it first. Good one, Bart).
    It's a 'utility' platform for the various cameras Fred Freketic is going to mount on it so he can get regatta footage from the center of the action. I've designed it to be big and heavy enough to plow through waves and wakes without bobbing too much like a cork.
    Currently working up zingers to toss back at Bart
      #2312
      Maybe think about a twin hull design catamaran.....I built the scale RC demonstrator model for a client of a twin hull (the 1/1 scale was was designed for seagoing duties)....it is an autonomous supply vessel for offshore windmill farms. The most stable platform is a Swath (Small Waterplane Area Twin Hull).
      ​ ​ ​ ​ ​ Click image for larger version
        #2313
        Food for though, sir. I'll consider it.
        • ffr2608
          • Oct 2009
          • 347
          #2314
          Lots of catamaran designs used for boat retrieval Dave. We had a pendulum type camera hanging below it....
          Based on personal experience, Go direct drive and buttery smooth driveline. That noise and vibration really transfers to the video.
          DH
            #2315
            DH
            Good stuff, Darrin. I will abide.
              #2316
                When your digit is thicker than the nail.
                  • 1393
                  #2318
                  What size of wood strips do you use to reinforce the plywood sheets?
                    #2319
                    I sincerely hope you're talking about the digit on my hand...
                      #2320
                      half inch X half inch. Had to rip inch X half inch to get it. NEVER EAZY!!!
                      • Ken_NJ
                        • Sep 2014
                        • 1006
                        #2321
                        Trying to be a wood worker are we?
                          #2322
                          Trying?
                          TRYING???
                          ****ING .... TRYING??????????
                            • 3770
                            #2323
                            Oh boy....let the sh*t storm begin. Grabbing my popcorn. LOL
                              #2324
                              • Ken_NJ
                                • Sep 2014
                                • 1006
                                #2325
                                I mentioned the idea to Tom and I think Steve H and Steve O at the 2022 Subfest of building a barge. It would be a combination barge, a push boat, rescue boat, camera boat. It would have mounts on the sides and bow above and below the waterline for a GoPro type camera. Was thinking of using telescoping K&S brass tubing, square or round, that can be removed and repositioned at any of the locations on the bow or sides. Even thought of having a round tube protruding from the center of the boat with a GoPro mount under the boat and above the waterline, inside, use a servo and gear mechanism to rotate this camera. Maybe have something on deck to indicate the camera direction, if you can see that far. The bow would have removable cushioned push posts to push a boat. The aft end was to have insertable rods that would stick out 90 degrees to the sides that could 'catch' a stranded surface model and push it along. They would be reversible port and starboard. There would be underwater LED lights, port, starboard and bow for night operations as well as LED lights for surface illumination much like my SS Miss Belmar party boat. On deck it would have a springer tug type of 'house' or control station. It would have the appearance of a naval yard tug. It would be about the same size as what you are doing but my construction method would be different than yours.
                                At one time I even thought of the bow camera being on a mechanism that could move the camera from above the waterline to below the waterline by RC, but my genius mechanical engineering friend passed away and that seemed to ambitious anyway.
                                Well that is my ambitious idea of a project I still want to build but I have many other projects now and in the future to build, some I might not get to. Your's David is a great start and I will learn your good and bads from what you are doing. Kudos to you for doing this non-submarine not your project type project!
