today's work
    • 3556
    #2986
    Submersible Tragflugelboot. Plan was to wait in submerged mode. Once the enemy was in range ballast tanks were blown and high speed attack and subsequent evasion was done on the surface.
    Here's something I wish Manfred made.
ID:	187965 Click image for larger version
ID:	187966 Rudolf Engelmann's Versuch Schnellboot 5 (Experimental Fast Boat 5 or VS 5) also known as Engelmann-boot, a semi-submersible, fast-attack torpedo boat for use in coastal waters. Armament consisted of two forward-firing, 21 in (533 mm) torpedo tubes in the bow and two 20 mm cannons atop the superstructure.
    • gantu
      • 407
      #2987
      Versuchs Schnellboot 5 (VS 5) Semi-submersible Attack Boat | Old Machine Press
      Regards Gantu
        • Jan 2020
        • 1027
        #2988
        harborfest, norfolk - Search Images
        I'll give you specifics when I get them, sir.
        Thanks David!
          • Jan 2020
          • 1027
          #2989
          David, do you have finished photos of your Type IX you can post sir?
            • 13741
            #2990
            Never finished it. Work got in the way. Retired, its now project 101 on my bucket-list.
              • Jan 2020
              • 1027
              #2991
              Oh, it will happen
                • 13741
                #2992
                • Ken_NJ
                  • Sep 2014
                  • 994
                  #2993
                  David, going back to the XXIII. From after the boat was completed, what problems did you encounter while running the boat and what were your corrective actions? This would be helpful for me and others going forward. Was it weight distribution, foam, dive plane issues, other issues? You mentioned to me at Subfest the CG was just aft of the front of the sail. We got cut short from the weather for me to take a detailed look at the boat.
                    • 13741
                    #2994
                    Severe pitch oscillations when dived. Initial placement of the c.g. and c.b. was at the hulls mid-point -- as you noted, that put the c.g. and c.b. at the sails leading edge. I then moved the c.g. and c.b. forward four-inches. No joy. This weekend I'm moving the c.g. and c.b. back four-inches aft of the sails leading edge. Film at Eleven.
                      • Jan 2020
                      • 1027
                      #2995
                      David, what sensitivity is the DC set to?
                        • 1600
                        #2996
                        Ordered mine.
                          • 13741
                          #2997
                          Originally posted by Das Boot
                          Ordered mine.
                          That's the one. Good stuff.
                            • 13741
                            #2998
                              • 1548
                              #2999
                              So you're took up the gauntlet to get the XXIII to run good, made a usefull observation at Gangelt Germany, was running my XXIII and during higher speeds she took the plunge to the bottum, steering divingplanes full down, i could see that because it was inside clear water at the swimmingpool, i wonder i it has something to do with the AFD with higher speeds.
                              To my surprice the XXI ran great without a ADF, i want to remove the ADF from the XXIII to see if that will give the same results as with the type XXI in handling underwater, i'll report back with the results.
                                • 13741
                                #3000
                                I'm all ears, Manfred. I'm completing the re-trim of my Type-23 tonight -- this third change of the boats c.g.-c.b. about seven inches aft of the initial c.g.-c.b. position, which was, when first operated, at the boats longitudinal mid-point. Open water test this Sunday. Film at Eleven, my friend.
