today's work
    • 14012
    #2836
    David, why nitro-stan on the hatches?
    Got that Xia-Kit still in the Box, too.
    Jörg
    The two forward missile hatches were separate from the rest which were engraved. After glueing the two hatches flush with the deck I was compelled to re-scribe the hatch outline, which left a scared deck needing fill. Also, I actually drilled vent holes atop each missile hatch as that would be better looking than the lightly engraved circles provided on the kit part. Some of those needed filling. So... I said, what the hell, and puttied all the hatches for symmetries sake.
      Would have been great if Trumpeter made all the hatches separate pieces for static displays.
        • 14012
        #2838
        I've seen a Trumpeter test shot of a version of this kit with all missile hatches open.
          You must be pertaining to the HobbyBoss kit not Trumpeter. 1/350 scale. Click image for larger version
Name:	images (1) (17).jpg
ID:	186362 Click image for larger version
ID:	186364 Click image for larger version
ID:	186365 Click image for larger version
            • 14012
            #2840
            That's what I get for making an assumption. Yes, you're right: two different kits with different scales. My bad.
              Where did you get your reference photos showing the grid patterned holes on top the missile hatches? Click image for larger version
ID:	186520 Click image for larger version
ID:	186521 I have yet to see photos the actual missile deck with the hatches closed.
ID:	186524 I did however saw a photo of the Type 94 Jin class SSBN, successor to the Xia class showing the holes on top of the missile hatches arranged in a radial pattern.
              What are the chances those on the Type 092 are layed out in a similar pattern?
                • 14012
                #2842
                Don't know. Went with Trumpeter's interpretation. There are subtle differences (and a few not-so-subtle) between the 092 and 094 class.
                With most projects these days -- with the clock hands ever closer to 12 -- I tend to be less anal retentive, and more pragmatic. Not yet totally useless, but not the sharpe tool I used to be.
                  • 14012
                  #2843
                    • 14012
                    #2844
                      • 979
                      #2845
                      CB Progressing. First CB Midget sub test. scale off, 3/4 inch too short. Second one adjusted up to 1/32 scale. Overall length will be 18.25 inches (463.55 mm). Print time 16 hours. New one printing now will take 20 hours for these two hull halves.
                      Enough detail Davd?
                      Click image for larger version  Name:	cb-post-1.jpg Views:	0 Size:	46.5 KB ID:	186593
                        She's a beauty.
                        Going with a vertical hull separation?
                          • 979
                          #2847
                          She's a beauty.
                          No, the plan by Merriman is a waterline separation unless he changes mind.
                          Will see how second print to correct scale is for overall length check. Expected to know this evening. If bang on, then will print other components. A lot of gentle sanding will come next & then priming. Sanding to remove the striation chatter I call it. Normal for this. Others that have contributed to this, big thanks.
                            • 979
                            #2848
                            In meantime, dabbling with colors. Two schemes seem apparent. A straightforward medium gray waterline up and light green below. Also, a more dazzle like scheme to confuse outline. Anyone know the official colors of Regia Marina camouflage for Italian submarines in WW2? Specifically, the CB's.?
                            Adjusted the color emulsion tint and warmth using the skin tones and fortunately an Italian flag also present as a useful convenient shade comparison in photo 2. Color chips my best guess. Ultimately it maybe all jut academic, as I use rostellum colors usually covered with a clear flat as Bob Martin points out is very durable.
                            The top photo here amuses me. Midget sub simplicity using the normal background fishing boats to blend in from air reconnaissance. Lol. It works.
                            Click image for larger version  Name:	italian-minisommergibile-cb-mar-nero-yalta-1942-midget-submarine.jpg Views:	0 Size:	61.6 KB ID:	186597Click image for larger version  Name:	CB-color.jpg Views:	0 Size:	57.9 KB ID:	186598
                            Click image for larger version  Name:	CB-Italian-Midget-Submarines-5.jpg Views:	0 Size:	68.5 KB ID:	186599
                            Click image for larger version  Name:	9513178359-701217d280.jpg Views:	0 Size:	64.5 KB ID:	186600
                            Click image for larger version  Name:	test-color-2.jpg Views:	0 Size:	22.6 KB ID:	186601
                            Click image for larger version  Name:	6291273051-d3401792a1-b-Copy.jpg Views:	0 Size:	55.1 KB ID:	186602
                              • 14012
                              #2849
                              The hull tool will consist of a five-piece rubber tool for the stern (capturing the horizontal and vertical stabilizers in one homogenous hollow resin casting). Like this:
                              and a three-piece mother-glove tool for the lower hull (one piece) and upper hull (two piece). A bit like this:
                                Click image for larger version  Name:	Screenshot_20250306_060410_Chrome.jpg Views:	0 Size:	69.3 KB ID:	186617
                                Different patterns of vent slots, top is alternating while bottom is in rows.
