today's work
    • 14014
    #3586
      • 14014
      #3587
        Just watched your latest youtube video about the 1/230 Skipjack.
        what's her static trim?
        How far up is sail submerged when stopped?
          • 14014
          #3589
          Only a quarter inch of sail projects into the air with proper trim established.
            • 14014
            #3590
              Will that 1.25" SD fit in the X-craft?
              recommended receiver?
                • 14014
                #3592
                Yup.
                Lipton-6 or the small Wfly receiver. Any number of small 75-72mHz receivers out there.
                  I built one of these as an Aurora kit, and I remember the little hatch at the top that showed the atomic reactor. How in the name of God, could you build an RC sub this small? What a glutton for punishment, but what a brilliant design. My hats off to you, David.
                      • 14014
                      #3595
                        Happy Easter.
                        CA? Why not a cohesive agent?
                          • 14014
                          #3597
                          Happy Easter.
                          Fair question. Though the horizontal stabilizer parts will be subject to most 'collision damage' underway -- and CA adhesive is subject to fracture under shock-loads -- a fusion joint would be the preferred attachment method. However, as there is so much 'footprint' between horizontal stabilizer root and surface of the stern, I figured that a CA bond would be substantial enough to resist breaking as a consequence of being hit by other craft or sides of the pool. And, using CA, eliminated the need on a fusion weld to change state through solvent evaporation... in old age I'm become less tolerant of delay.
                            I wonder why they put raised detail on the hydroplanes where there are ventilation holes are on the original?
                              • 14014
                              #3599
                              ****!... I don't know; I'm just the idiot model-kit-assembler here. (I'll fix those little problems after all the structural work is done, I have proper drawings of the original and 'improved' X-Craft).
                                Mold pattern maker must have gotten confused
ID:	194397 dimples or bumps
