today's work
    Coat of arms of the city of Pskov.
      • 14013
      #3572
      MOST helpful, Romel. Clear decal paper on order. Excellent!
        • 979
        #3573
        Click image for larger version  Name:	OMEzVe.jpg Views:	3 Size:	72.5 KB ID:	194339 Hi David, the Albacores parts are they in 1/60 (Asay's old kit) or in1/96?
        And do you make an aft prop set with 7 & 6 blades too? If in 1/60 I might purchase a set?
        Parts look beautiful.
          • 14013
          #3574
          These were sent to me as is (obviously, whoever did this insured he had the blade-count right; not like one idiot we know) and were 3D printed. I believe the scale is 1/48. Maybe Howard will chime in here and tell us more about these pieces.
            3d files can be easily scaled, all depending on whether the creator wishes to make them available.
              Really enjoyed your video David!
              "Firemen can stand the heat"+
                • 14013
                #3577
                Which one, Rob? Did you make yesterday's Zoom meeting?
                  • 14013
                  #3578
                    • 979
                    #3579
                    Thanks David. Howard the 3D Print gentleman must at some point seen photos of the museum sub. So I wonder if he has research information that Albacore tested the blade count in the above parts photo too at some point?
                    We know from your excellent accurate historical article you did decades ago and decades ago inspired me to join this 'clazy' hobby, you mention and I still remember Albacore tested several propellor combinations in Phase IV configuration.
                    Perhaps that involved different blade counts as well as separation between props too? The Portsmouth NSY foundry and milling machines in the Propellor department must have been a busy place then cranking out different hydrodynamic test propulsors. I know in the UK there was a 11-blade sickle blade shaped prop tested experimentally on one of the Valiant Class SSNs, but apparently it was at the very limits of the CNC technology then at that time and it lacked the robustness of a more usual 7 blade count. A one off,
                    In 1/48, at 210 feet in Phase IV, would be perfect size for the water internal space and the car truck transporting at 52.5 inches. Id love if available the STL files I can resin print one for myself.
                    "Now back to the regularly scheduled program"
                      • 14013
                      #3580
                      To the best of what I could find, no reference to variances in blade numbers. Just distance between the discs was altered and propulsion perimeters measured and recorded. I'm sure David Taylor went through a slew of propeller types, distances, and geometry before sending the drawings to the NSY for creation of the actual castings we are now so familiar with.
                      My agreement with Howard is to produce tools and parts from the masters he is sending me (more to come). From that tooling I'm to get a 'kit' as does Howard -- his to be assembled and painted. Contact him, he might be agreeable to letting me produce a kit for you. It's going to be his product, not mine. I'm only the idiot tool-maker on this job.
                        I understood these 3d files have been created from 3d scans of the original boat?
                          • 14013
                          #3582
                          That's right! Forgot to mention that in my response to Steve. Don't get lofting better than that!
                          Thanks for the follow-up, Andy.
                          • jphatton
                            • Jan 2021
                            • 112
                            #3583
                            Here is a 3D photometric scan of USS Albacore which is very detailed, you can use your mouse to view from all angles. Perhaps this was used for making the model?
                              • 979
                              #3584
                              Impressive. filé, Its astonishing these days. Imagine agents with hidden 3d scanners in submarine yards scanning a classified sensitive part of the sub under construction. If I thought of this, a dummy like me, the agencies that like to refer to themselves as 'the company' surely must have thought of it too.
                              Scan is accurate even down to the hull cuts for touring her so why did Howard them make his STL files to print then with wrong blade counts on both props? Proprietary? Whatever.
                                • 14013
                                #3585
