today's work
    • 13729
    #2086
    • DrSchmidt
      • Apr 2014
      • 1343
      #2087
      Beautiful....
        • 13729
        #2088
          • 13729
          #2089
          • Marylandradiosailor
            • Nov 2021
            • 70
            #2090
            HWSNBN ... does the RubnBuf gold dry to a hard coating? I have read some complaints on other modeling forums that folks have said it always remains a bit soft ? TIA, Khim
              • 13729
              #2091
              It's more of a 'smear' type coating, petroleum or animal oil/wax binder-solvent. Best applied over a rough surface such as a flat finish where the 'grainy' surface gives enough tooth to hold the medium in place without risk of shrugging off do to handling or accident.
              It eventually dries hard, but it has low adhesion to a smooth substrate, but will cling well to a rough substrate.
              • DrSchmidt
                • Apr 2014
                • 1343
                #2092
                Can you polish RubnBuf? I use wax based metal colors (https://ak-interactive.com/product-c...-metal-paints/) that are very nice, that can be polished, but which can be partially rubbed off, even when applied on primer.
                  • 13729
                  #2093
                  Yes, they can be polished to a nice sheen. But, as you pointed out, are also subject to abrading away if polished too aggressively. In this case I put the Rub n' Buff on neat as it will later be weathered to match the mung seen on the lower hull.
                    • 1939
                    #2094
                    I know that I have stated this before! But your skills for applying your authentic paint schemes and weathering to your boats is masterful. I have at one time suffered your painful thoughts of what I have done on most of my boats. (a rattle can jockey, and just out of drydock schemes)
                    You have laterally shamed me into wanting to do better in the area of more authentic paint schemes and learn to do weathering. And so, I think my German 212 A boat will be a good starting point.
                    Thank you very much for all the great work that you do and posting it up. You are a real inspiration for us ALL to follow!
                    "Firemen can stand the heat."
                    • Ken_NJ
                      • Sep 2014
                      • 994
                      #2095
                      D.M. I hate you.
                      Well not really.
                        • 13729
                        #2096
                        Originally posted by Ken_NJ
                        D.M. I hate you.
                        Well not really.
                          • 13729
                          #2097
                          When you start smearing things on that model of yours and get hung up on something, don't hesitate to give me a shout. I'll be merciful... I'll use the sharp knife; you won't feel a thing, pal. Welcome to the big-league.
                          The Horrible
                          • bwi 971
                            • Jan 2015
                            • 940
                            #2098
                            Fantastic that you provided the letters in way of the securing & lashing point hatches.
                            Grtz,
                            Bart
                            "Samuel Smiles"
                              • 13729
                              #2099
                              Grtz,
                              Bart
                              Yes. A happy occurrence that the number 3 on the Woodland Scenic dry-transfer set #747 was the size and shape of the Russian submarine latch identification marking. Fortun smiled in this situation.
                                • 13729
                                #2100
