today's work
    • 13988
    #2041
    David, I see in the last few photos that you had some orange peel from a clear coat (I am guessing). How do you correct it? Do you sand it out completely or just paint over it? Every once in awhile I get that from rattle cans and it ****es me off. One time it works and then it doesn't.
    Orange peel in this case the consequence of too little extender and thinner -- the spray started to congeal in the air on its way to the works surface. This was a 'protective barrier' clear coat, preparing the surface for water-slide decals, masked off and painted panel outlines, and dry-transfer rub-on markings; all that followed by another layer of streaking, running rust, and some oil-canning effect.
    Since there is yet to be applied a well flattened clear coat later, it was enough to knock down most of the orange peel with a good wet sanding with #600 grit sand paper. That last coat of clear will be well reduced in viscosity and shot at a lower pressure; with the nozzel very up-close-and-personal to the work -- that coat will go down super wet.
      • 3761
      #2042
      Thank you! I do the same and I like seeing how you overcome this.
        • 13988
        #2043
        • ffr2608
          • Oct 2009
          • 347
          #2044
          Dave,
          This thread is currently 136 pages of modeling awesomeness. Every page has a plethora of information and correctly placed photos. Excellent work showing us how it's done.
          Hope to meet up again in the fall and run some boats together.
          Darrin
            • 13988
            #2045
            Originally posted by ffr2608
            Dave,
            Darrin
            Darrin,
            I don't often fawn in public over a complimentary post. But, here I go: Such nice comments -- coming from a true, well accomplished, and talented model-builder as yourself -- is most gratifying. Thank you sir.
            (where do I send the check?....)
            **** yeah! I'll be making both the Groton and the Red-Clay events. You?
            Who Now Can't get his over-inflated Head Through The Door
              • 13988
              #2046
                • 13988
                #2047
                • Ken_NJ
                  • Sep 2014
                  • 1006
                  #2048
                  Does that binder contain just those half dozen or so color pages or more? Can you bring that binder to Gorton and Subfest please?
                    • 13988
                    #2049
                    Will do, Ken. And if there is enough room on the tables I'll bring my binders of photos.
                    • ffr2608
                      • Oct 2009
                      • 347
                      #2050
                      Dave,
                      Trying for Georgia again with something to run this time.
                      Darrin
                        • 13988
                        #2051
                        Dave,
                        Darrin
                        Excellent, excellent! No matter, I'll have plenty of boats, so you'll have a ride, no matter what, Darrin​​
ID:	178764 Click image for larger version
                          • 13988
                          #2052
                            • 13988
                            #2053
                            • goshawk823
                              • Oct 2010
                              • 262
                              #2054
                              Hey David? Is that the renshape (spelling?) I’ve heard about so often?
                                • 13988
                                #2055
                                Indeed, Sam. The light colored stuff is 20 lbs. RenShape which machines like butter but has a course finish. The darker stuff (the stem at the bottom) is the dense 40 lbs. RenShape.
