Looking great, Rob. It would be good to see that Albacore wet!
I am ready to start another 3D Printing project! I have an old Albacore Boat that purchased from Nautilus Drydocks (Bob Martin) I have taken out all the old electronics that where in fairly good shape, but the ballast tank had some cracks and the WTC was warped and leaked very bad. I will use as much of the old electronics and the propulsion motor to keep it as close to original as possible.
The hull seems to be ABS plastic and in good shape. What I am going to do is design and fabricate another 3D Printed 3.5" WTC/SD and adapted the old electronics and the motor to the new WTC. I have decided to make this Albacore a dynamic diver! This will be another step closer to a full static diving sub for me!
Who is John Galt?Comment
The only changes I am making to this boat is the WTC that I will 3D fabricate to replace the old warped and crack compartment that came with the boat, and in place of a static diver it will be a dynamic diver.
Very good. A most interesting lease-on-a-new-life project. I'll be following it with interest.
DavidWho is John Galt?Comment
I am starting to work out different ideas for the motor mounting system for the WTC. Trial and error at this point!
I have two 3.5" X 12" Acrylic tubes coming to be used as the equipment housing for the WTC. This system will the same basic design as the one I built for the Astute and the Redoutable!
"Firemen can stand the heat"Comment
Progressing on the design phase of the WTC for the Albacore. The red PLA printed items at this point will be replaced with a different color and correct sizing. It's all prelim. right now!
I have the bottom half of the existing hull cleaned up and re-glued where necessary..
Thanks Bob!
I want to clean up both the top and bottom hull and put on a coat of quality primer. I like a nice clean interior and some sort of organization for the electronics, wiring, battery, and motor, (I know, it's a sickness I have) It all started with our Fire Trucks!
Thanks Bob!
It will be nice to see it running! The old equipment, if it still works, had subs running wonderfully 20+ years ago. So, it is very cool you are going to get it working using the older tech.If you can cut, drill, saw, hit things and swear a lot, you're well on the way to building a working model sub.Comment
I went through the electronics, and everything seems to be working OK! The motor and belt drive gear system is also working, and by looks of the prop size it should move through the water with some authority!
The old Hitec receiver had some internal water damage so I will be replacing that part of the system and using my VEX TX & RX system. Also the original owner removed one of the mounting supports on one side of each of the two Hitec HS-322HD servos. They do work, so I will design a mount for them as well.
This will be a fun project, and we will see what happens!
