3D Printing Submariens and Sub Components
    Looking great, Rob. It would be good to see that Albacore wet!
      • 13998
      #77
      Originally posted by rwtdiver
      I am ready to start another 3D Printing project! I have an old Albacore Boat that purchased from Nautilus Drydocks (Bob Martin) I have taken out all the old electronics that where in fairly good shape, but the ballast tank had some cracks and the WTC was warped and leaked very bad. I will use as much of the old electronics and the propulsion motor to keep it as close to original as possible.
ID:	138188Click image for larger version
      The hull seems to be ABS plastic and in good shape. What I am going to do is design and fabricate another 3D Printed 3.5" WTC/SD and adapted the old electronics and the motor to the new WTC. I have decided to make this Albacore a dynamic diver! This will be another step closer to a full static diving sub for me!
      I have a bunch of proper parts to help you along with that hull, Rob. I assume you're going to assemble this thing as the ALBACORE, phase-2?
ID:	138199Click image for larger version
ID:	138200Click image for larger version
ID:	138201Click image for larger version
ID:	138202Click image for larger version
ID:	138203Click image for larger version
ID:	138204Click image for larger version
ID:	138205Click image for larger version
        The Albacore that I am rebuilding is the same as the photos above. The only change I am making is it will not be a static diver! I am going to use all the old existing electronics and motor that came with this boat. I will keep it as close to what the original boat looked like as possible. Thanks David! The parts you have seem to be the same way the boat is already built at this point.
ID:	138223Click image for larger version
        The only changes I am making to this boat is the WTC that I will 3D fabricate to replace the old warped and crack compartment that came with the boat, and in place of a static diver it will be a dynamic diver.
          • 13998
          #79
          Very good. A most interesting lease-on-a-new-life project. I'll be following it with interest.
            I am starting to work out different ideas for the motor mounting system for the WTC. Trial and error at this point!
ID:	138268Click image for larger version
            I have two 3.5" X 12" Acrylic tubes coming to be used as the equipment housing for the WTC. This system will the same basic design as the one I built for the Astute and the Redoutable!
              Prelim. design and mock-up of the motor mounting section is on the move!
              Final motor unit will not be fabricated until the Acrylic tubes arrive so that I can true up the final measurements.
                Progressing on the design phase of the WTC for the Albacore. The red PLA printed items at this point will be replaced with a different color and correct sizing. It's all prelim. right now!
ID:	138372Click image for larger version
                I have the bottom half of the existing hull cleaned up and re-glued where necessary..
                • SubDude
                  • 825
                  #83
                  Looking really good Rob. That hull cleaned up nicely.
                    Thanks Bob!
                    I want to clean up both the top and bottom hull and put on a coat of quality primer. I like a nice clean interior and some sort of organization for the electronics, wiring, battery, and motor, (I know, it's a sickness I have) It all started with our Fire Trucks!
                    • SubDude
                      • 825
                      #85
                      Thanks Bob!
                      Actually its Steve but you can call me Bob. ;o)
                        Sorry Steve! You are in my log book!:-)) Thanks again for your compliment!
                        • george
                          • Dec 2010
                          • 731
                          #87
                          Hi Rob
                          No it`s not a sickness, neat is always better during setups of equipment. Easier later on to find faults and repair them.
                          George
                            Just got word today that my 3.5" cylinders have shipped and will be here Saturday! Now I can get back to the Albacore build!
                              • 3768
                              #89
                              It will be nice to see it running! The old equipment, if it still works, had subs running wonderfully 20+ years ago. So, it is very cool you are going to get it working using the older tech.
                                I went through the electronics, and everything seems to be working OK! The motor and belt drive gear system is also working, and by looks of the prop size it should move through the water with some authority!
ID:	138734Click image for larger version
                                The old Hitec receiver had some internal water damage so I will be replacing that part of the system and using my VEX TX & RX system. Also the original owner removed one of the mounting supports on one side of each of the two Hitec HS-322HD servos. They do work, so I will design a mount for them as well.
                                This will be a fun project, and we will see what happens!
