today's work
    • Jan 2020
    • 1035
    #3061
    David why this model?
      Tell me you're RCing this.
        • 13948
        #3063
        Why not. Small for little pools, only four-channels required, easy to take around as carry-on, and I like the smalls stuff.
        Click image for larger version  Name:	012.jpg Views:	0 Size:	79.4 KB ID:	188504
          Click image for larger version  Name:	20250612_220812.jpg Views:	0 Size:	41.5 KB ID:	188509 here's mine with a 40mm tube.
          Click image for larger version  Name:	20250612_221814.jpg Views:	0 Size:	71.3 KB ID:	188510 Click image for larger version  Name:	20250612_221915.jpg Views:	0 Size:	25.9 KB ID:	188511
          diy endcaps made from plastic plugs and orings
          See that you glued the saddle charges to the hull.
          Have this idea of using magnets to make them removable to show an unarmed boat. They also help hide the seam if you're going with a longitudinal hull cut.
            • 13948
            #3065
            Talk'n parts done.
              • Jan 2020
              • 1035
              #3066
              Just wondering if the British XMS X-Craft had any special meaning to you
                • 13948
                #3067
                Nope. Just another modeling project.
                  • 13948
                  #3068
                    • 13948
                    #3069
                      Doesn't the 2" subdriver for the 1/72 type vii have a 7 oz ballast tank volume? If that 6.7 is in ounces then you're in luck.
                      • DrSchmidt
                        • Apr 2014
                        • 1393
                        #3071
                        Lovin it.....
                          • 13948
                          #3072
                          Lovin it.....
                          You have been so patient with me. Time for me to fulfill my obligation, made over a year ago. In the intervening months I've been able to ready my boats for regattas and do some one-on-one training of local talent.
                          Tonight I put all the U-1's tiny masters onto the first half of the spin-casting tool embedment, and start in on the ugly job of clay-masking those open framed 'box' do-hickies.
                          The objective is to produce parts for you and me -- with three extra sets for you to pass out as you please.
                          At the conclusion of my work I will send you all master, tools and assembly jigs (if any, don't know if any will be needed at this stage).
                          • DrSchmidt
                            • Apr 2014
                            • 1393
                            #3073
                            I think there's no need to make masters for the mast boxes. Those can easily be 3d-printed....
                              • 13948
                              #3074
                              OK. That's a load off the table. Thanks. Can I keep the set as parts for my boat? (tooling -- though doable for those items -- would have been, ah, ... Interesting).
                              Time for my hideous nap. After that, onto the spin casting tool.
                                • 13948
                                #3075
