today's work
    • 3613
    #2686
    Merry Christmas to you and Ellie.
      • 13831
      #2687
      Yup. Same to you and yours.
      • DrSchmidt
        • Apr 2014
        • 1357
        #2688
        Merry Christmas....
          • 3613
          #2689
          same brass eyelets you use to secure Propel tubing.
            • 13831
            #2690
            Yes. And they do the same job here, but instead of tightening the hose around a static length of gas/liquid piping, the grommets make fast rotating shafts to the hose -- this assembly serving as a universal coupler between motor and propeller shaft.
              • 3613
              #2691
              Just tap to secure and to release.
                • 13831
                #2692
                  • 3613
                  #2693
                  Surely a contour gauge would be faster than plotting individual points by hand to get the outline of the hull?
                    • 13831
                    #2694
                    The more severe the objects draft, the less precise the contour gauge becomes.
                      • 3613
                      #2695
                      Understood.
                        • 13831
                        #2696
                          • 13831
                          #2697
                            • 1602
                            #2698
                            Question, at which setting you run the ADF?, got to know for the future, still have to order some ADF's from Bob together with some other needed stuff.
                            Manfred
                              • 13831
                              #2699
                              Manfred
                              For a new boat -- and I've only got a few minutes underwater time with my little Type-21 -- I set the ADF to its least sensitive setting. The Type-21 was rock-steady about the pitch plane with the ADF set to the lowest sensitivity setting.
                              Only rarely do I find a boat that needs a more responsive angle-keeper.
                                • 1602
                                #2700
                                Thanks, it will be noted down for the future, saves time adjusting the ADF
