today's work
    • 14012
    #2611
      • 14012
      #2612
        How is it you always outdo yourself?
          Correct.
          Cyanoacrylate is best suited for this task -- it is fast setting; easily broken away (fails readily in shear) for re-alignment/replacement; and is adequate for the job of bonding dissimilar materials which are not chemically able to fuse together at room temperature.
          Got mine in today. Nice Winter project. I finally got a place where I can get models together. It’s nice to be empty-nesters with three bedrooms to spare. One for my man cave/model room. Click image for larger version
            Originally posted by Das Boot
            Got mine in today. Nice Winter project. I finally got a place where I can get models together. It’s nice to be empty-nesters with three bedrooms to spare. One for my man cave/model room. Click image for larger version  Name:	IMG_7683.jpg Views:	0 Size:	54.8 KB ID:	184379
            OK Casey! With all the chatting you enjoy doing on this forum! How about a build blog on your new Kilo class submarine?!
            "Firemen can stand the heat."
              I’m no good with blogs, but I’ll try to take a bunch of pictures and then do some narrative after a bit. It’s gonna take a 2 inch WTC.
                Rob, thats NOT a Kilo. It's the Trumpeter 1/144 Chinese Type 092 Ballistic missile submarine.
                  OK! Couldn't see the writing on the box that well without my magnifier. (sorry, I wasn't even close, but it is a submarine) Got to laugh! We better get off Davids build blog, or we will be in for it...;-))
                    • 14012
                    #2619
                      • 3772
                      #2620
                      When you install the plastic ring (polycarbonate?), do you add pressure against the o-ring or just snuggle up to it? In other words are you compressing the o-ring any to add its friction fit against the pipe?
                      Love your documentation....lots to learn from you.
                        • 14012
                        #2621
                        The sealing is affected at the outer and inner surfaces of the O-ring, so compressing it is only required if the fit between bulkhead body and conduit tube is loose. So, I select an O-ring diameter that is a bit smaller than the conduit, and a bit larger than the bore of the bulkhead it fits within. The 'compression' ring is not that at all -- its only purpose is to retain the O-ring within the bore as I install/remove the conduit tube.
                        I went through all this voodoo bull**** because I wanted a larger diameter conduit than my stock bulkheads were designed for. Here's the standard O-ring, encapsulated during the bulkhead casting operation:
                          • 3772
                          #2622
                          I am very familiar with your past standard o-ring. I like this "New" way. Thank you for answering.
                          Tom
                            • 14012
                            #2623
                            • goshawk823
                              • Oct 2010
                              • 262
                              #2624
                              is that a 1/72 scale Alfa? I’d swear if looks like my old boat from the spray and fittings inside the hull.
                                Looks like a Skipjack.
