today's work
    • 13824
    #1486
    Let's see if I got this correct.
    To determine the volume of the ballast tank needed for your Nautilus you first weigh everything that's above the water line when the boat is surfaced. You then get a length of polycarbonate tubing set it on the scale, tare it to zero then slowly fill it with water until the weight of the water matches the weight of the above waterline items. You mark out the water level in the tube giving you the length of the ballast tank needed. Maybe add 10-15% margin to account for the items that go inside the tank like linkages, gas bottle, SAS float.
    Bingo!
    As GRP has about the same specific gravity of fresh water the relationship is direct, if the freeboard material varies from fresh water, then you plug in the ratio and a little math tells you the weight of water needed.
      • 3610
      #1487
      Bingo!
      Say you're building a GRP Space Battleship Yamato anime submarine with the massive superstructure and deck guns. What do you do when the resulting length of the BT exceed the available space in the WTC and hull?
        • 13824
        #1488
        Then your ****ed!
          • 13824
          #1489
            • 1622
            #1490
            Cool looking saw. Never seen one like that before.
              • 3610
              #1491
                • 3610
                #1492
                Innovative use of a b**tplug for the ram.
                  • Oct 2017
                  • 1013
                  #1493
                  He could have used chainsaw for hobbywork?
                    • 13824
                    #1494
                    The stuff of legends!
                      • 2012
                      #1495
                      The Mason Nautilus is a favorite of mine. I think I've been lucky enough to build up 3 of them so far. Ray did an amazing job on those boats.
                        • 13824
                        #1496
                          • 13824
                          #1497
                            • 13824
                            #1498
                              • 3704
                              #1499
                              Almost need to smoke after this posting. As usual I pour over your photos to glean what I can and recognize what I cannot do. Thank you for these images.
                                • 1622
                                #1500
                                Submarine Sex.
