today's work
    • 981
    #1426
    OTFLMAO!!!
    I never even thought of that 'hand-of-God' thing while checking the field-of-view, and depth-of-field while the system was underwater. Leave it to a hard-core SF nut like you to dig out that old ST chestnut, Steve!
    Yeah. I missed a trick by not violently rocking the model back and forth at the end of the video.
    Here's a related video, just for you, pal: https://youtu.be/CxfA5d2L0BA
    Thanks Buddy, Enjoyed the Video very much. Steve
    • neitosub
      • Nov 2021
      • 163
      #1427
      Hi David,
      What’s the volume of the ballast tank that you used for the Bronco XXIII conversion? You probably had to take into account the weight of the camera assembly in the conning tower I imagine? Would you happen to recall the weight of the upper hull assembly above the waterline by any chance (minus the camera assembly that is)?
      Thanks,
      Nate
      • James Wittaker
        • Oct 2021
        • 67
        #1428
        Adjust the weight of the video equipment to roughly neutral buoyancy, and you'll know how much water you need to displace.
        • neitosub
          • Nov 2021
          • 163
          #1429
          Not planning to install video equipment in mine, just wanted to know the weight of the hull above the waterline, the hull looks to be made out of thin styrene so it shouldn't weight much I'm guessing?
          Nate
            • 14014
            #1430
              Good size boat. Plenty of room.
              • george
                • Dec 2010
                • 731
                #1432
                HWSNBN Sir. I have seen that you have worked on some improved Fittings related to the 1/35 Bronco Type XXIII, not Video related But ALL other improvements. Would you consider making a set for me, I just found a Type XXIII locally and would like to make it Static R.C and have your improvements. Please let me know. Thanks fr your time.
                  • 14014
                  #1433
                    • 14014
                    #1434
                    I'm retired. These items will soon be available from Nautilus Drydocks, they got all the fittings kits masters and tooling.
                      That is your masterpiece. Sweet.
                      • george
                        • Dec 2010
                        • 731
                        #1436
                        Thanks for the update. I will keep an eye on the Dry Dock site.
                        • wlambing
                          • Nov 2020
                          • 402
                          #1437
                          The 637 is looking sweeeeeetttt!!!!!!!!!!!!
                            • 14014
                            #1438
                            Yeah, it's gonna be ready for Red Clay. And thanks for your help with this project, Bill.
                              • 14014
                              #1439
                                • 14014
                                #1440
