GATO! (It has begun)
    I didnt know that. Thanks Mike.................er.................but no butt kissing.
      So where are we Dave with this stuff? Since the Sombra went away, have we got a reciever worth its salt? Is the WFLY reciever the suggested replacement?
        • 13650
        #183
        Yes!
        In spite of my initial negative evaluation of the WFly receiver ... which was WRONG -- I had not figured that the damned thing had default 'zero' settings on all channels, so I could not get it to play nice with the ADF2 -- it is an ideal receiver for our use: small of foot-print (once you yank it out of its plastic case and stick it in some heat-shrink tube); the channel fail-safe points are easily programmed into it just using the transmitter (thank you, Tom, for teaching me that trick ... which changed EVERYTHING!); is very selective; is cheap; and is readily available.
          • 13650
          #184
          Yes!
            • 3670
            #185
            Not to jump too far ahead, but when you have multiple subs, you can kick it up a notch by adding a crystal-less module
            The Futaba is nice because you can change the frequency with out removing the module. The Hitec has the settings on the side.
              • 13650
              #186
              [ATTACH=CONFIG]26582[/ATTACH]
              Sauce for the Goose.
              • crazygary
                • Sep 2012
                • 610
                #187
                Sorry, in advance, but this is a bit "off topic", however it does deal with the WFly 6-channel receiver!
                In surfing-the-net, I came across this: WFly FRP06_P receivers for what looks to convert from Chinese Yuan-to-USDollar
                for 17 bucks!!! Helluva deal!! (105 Yuan = 17USD)
                Here's the url: www.ldmx88.com/en/pro_view.php?id=3143
                Hey, Mike!! Suck up a bunch of these bad boys!!!!
                I may just cash in on a couple right now!!
                CG
                  Why does it show such a short antenna wire?
                  • matthewnimmo
                    • Dec 2011
                    • 271
                    #189
                    Thanks everyone for the radio info. Im sure ill have more questions (hopefully this weekend) about the radio system and what i need to do to configure it appropriately for the gato
                    any response on the fuse size i need for my gato wiring 5, 10 amps?
                      • 3670
                      #190
                      10 amps. quick blow and if you need help on the radio, let me know.
                      • crazygary
                        • Sep 2012
                        • 610
                        #191
                        Ya got me, Greenman407!!
                        Two possibilities: 1 - It's a new,"state-of-the-art" microwave type antenna, or
                        2 - The guy whut took the pitcher is a dumbass????
                        CG
                        • crazygary
                          • Sep 2012
                          • 610
                          #192
                          I tried to score a couple of those WFly receivers, and was doing pretty well, then all of a sudden,
                          I realized that my Chinese ain't so much purty good anymore: As in, Ah wuz totally clueless, so I bailed!!
                          I doan know none Chinese!!! Engrish be hard enuff!!
                          C'mon, Mike!! Make it happen, brother!!!!
                          CG
                            • 3670
                            #193
                            CG
                            Did you ask Mike if he had any to sell? I think he does and was comparable in price and 8 ch to boot.
                            • matthewnimmo
                              • Dec 2011
                              • 271
                              #194
                              Thanks trout, taking Davids advice on just gettingthe normal wiring done first. But as i build out the tower and the rest of the sub what areas do/should i precut out to make room for lightining on the sub. Refering to the lights you had done on your gato Trout
                              • crazygary
                                • Sep 2012
                                • 610
                                #195
                                Hi, Tom!!
                                If he does, they're not on the website!!
                                I have one, but thought that at such a cheap price, I'd grab a couple more!!
                                CG
