Moebius Skipjack
  • Ken_NJ
    • Sep 2014
    • 1001
    #91
    Nice Bob. I like it. Was going to experiment this week on a few ideas. Will give it a try. Thanks!
    • Ken_NJ
      • Sep 2014
      • 1001
      #92
      I have these center finding clear flexible rulers. They come in handy for many things. Bought them on Amazon.
      • Ken_NJ
        • Sep 2014
        • 1001
        #93
        It's a submarine! Nice to see an entire hull!
        • Ken_NJ
          • Sep 2014
          • 1001
          #94
          Some issues. The lower hull sections are off. All I can think of is sand away some of the high side and use filler on the low side. Thoughts about this?
          Click image for larger version  Name:	IMG_2756.jpeg Views:	0 Size:	37.7 KB ID:	147401
          Starboard side, have a gap between the upper and lower section in the corner. The lower section is on top in this picture. I’m working on the radial gap by cutting the gap to equal width then filling with styrene.
          Click image for larger version  Name:	IMG_2758.jpeg Views:	0 Size:	25.6 KB ID:	147400
          This is the port side. Same gaps in the corner between upper and lower sections.
          Click image for larger version  Name:	IMG_2759.jpeg Views:	0 Size:	24.5 KB ID:	147399
          The upper topside hull sections are not as bad as the lower hull. This is the glazing putty I have on hand. Should I use this as filler?
          Click image for larger version  Name:	IMG_2760.jpeg Views:	0 Size:	75.8 KB ID:	147402
          • Ken_NJ
            • Sep 2014
            • 1001
            #95
            David, any suggestions on the misalignment on the hull sections, first picture? And the gaps in the corners?
              • 13842
              #96
              Lay on that two-part filler you're using and even up the depressed side to match the high side. Lay on some angel-hair impregnated with laminating epoxy (West system recommended) over the filler portions. This will keep the filler from delaminating later and to toughen the models surface to something near uniformity with the polystyrene the kit's made of.
              Use CA and baking soda to fill the radial and longitudinal gaps. Overlay the glass here too.
              Sand, another coat of thinned epoxy resin (cut it with lacquer thinner), and sand. Prime, and carry on.
              Finish that damned boat, then drive it like a rental!
              • Ken_NJ
                • Sep 2014
                • 1001
                #97
                I have not worked with angel hair before, this stuff?
                https://www.google.com/aclk?sa=L&ai=...gQIHBA9&adurl=
                Wouldn’t a coat of epoxy create quite a ridge and be difficult to fair where it ends?
                • Ken_NJ
                  • Sep 2014
                  • 1001
                  #98
                  Never worked with angel hair fiberglass, this it?
                  Wouldn't a coat of epoxy create a ridge and be difficult to fair into the polystyrene where it ends?
                    • 13842
                    #99
                    No.
                    .74 ounce-per-square-yard fiberglass cloth. 0.73 oz Style 106 Fiberglass Cloth with Volan Finish - Fiberglass Cloth Supply and Education (thayercraft.com)
                    Light weight stuff. Sanding will feather edge the transition from cloth laminate and polystyrene surface. That fairing is also the job of putty and primer.
ID:	147431Click image for larger version
ID:	147432Click image for larger version
                      • 3621
                      #100
                      How about thin plastic card bonded to the underside?
                        • 13842
                        #101
                        ...how about taking advice from a guy who's actually finished something.
                          • 3621
                          #102
                          Wasn't giving. I was asking.
                          • Ken_NJ
                            • Sep 2014
                            • 1001
                            #103
                            First coat of cloth/epoxy is on and drying. I’m looking way ahead. What paint, manufacturer, should I use? I have a new airbrush I can use. I’d assume most of the paint should be flat? Not sure the zinc chromate is available?
                              • 3715
                              #104
                              Ken,
                              Take a look at Revell’s suggestions: https://downloads.revell.de/Manuals-Modelkits/05119.pdf
                              David can speak to the accuracy of any of it.
                              • Ken_NJ
                                • Sep 2014
                                • 1001
                                #105
                                Thanks Tom, will check into it. Yea would like to hear from David.
                                In the meantime feathering the first coat of epoxy. I added gray colorant but it came out translucent. The one thing I dislike most about model building... sanding.
                                Click image for larger version  Name:	CCA47C8B-56AB-4666-8B58-A8A15EE3E04E.jpeg Views:	0 Size:	59.1 KB ID:	147488
