Nice vid what's involved running a rc submarine, both pre mission as post mission
As for my type XXIII, cg is under the middle of the tower, angle keeper at it's lowest setting, speed limited to 50%, when run on max power she will take the plunge.
I guess it has to do with the hull shape, the V80 loves to run fast ( different hull shape)
That dolphin movement of the boat can be due to the levelkeeper being too sensitive, had the same issue with the V80, turned down the levelkeeper each time untill i had a straight run, i must admit the V80 has a levelkeeper from Norbert.
