today's work
    • 3377
    #2266
    turning it all into tooling that will permit production of 1/96 Type-21 hulls.
    take my money...
      • 13390
      #2267
      • DrSchmidt
        • Apr 2014
        • 1235
        #2268
        Very nice...
          • 3377
          #2269
          Is the rudder post glued to the rudder piece and freely rotates in the top and bottom stern section
          or does the rudder piece pivot around a fixed rudder post?
            • 13390
            #2270
            The rudder operating shaft is a jam fit to the skeg sections and the bore of the rudder is a non-interference fit to the operating shaft. It takes only moments to install/remove the entire rudder assembly.
              • 13390
              #2271
                • 3377
                #2272
                Interference Fit. Got it....
                  • 13390
                  #2273
                    • 3377
                    #2274
                    Will you be punching out ALL of the limber holes?
                      • 13390
                      #2275
                      Nope, just the above waterline ones. I'll punch fake flood-drain holes in the bottom of the keel.
                        • 13390
                        #2276
                          • 3377
                          #2277
                          Commercial Break.
                            • 13390
                            #2278
                            Commercial Break.
                            Fellow Torpedoman and all-round pain-in-the-ass, 'Jake'. Getting his 1/96 SKIPJACK up to speed. Class is in session!
                              • 1487
                              #2279
                              Jake,
                              a before and after shot of the hull would show the great deal of work that was accomplished. Well done.
                                • 3377
                                #2280
ID:	181313 Does Jake incorporate static grass/flock to replicate the "marine growth" on the hull?
