today's work
  • bwi 971
    • Jan 2015
    • 940
    #1861
    Solder wire thats a good idea.....bendable....better than stubborn brass.
    "Samuel Smiles"
      • 13728
      #1862
      We exploited the virtues of solder wire while building this forced perspective miniature hangar and other items for a slasher flick:
        • 13728
        #1863
        • Ken_NJ
          • Sep 2014
          • 992
          #1864
          I hate sanding/finishing into fine corners like you did. Still have to perfect that technique.
            • 13728
            #1865
            You big goof-ball! I've seen your work. You're already doing it! Here are some abrasive tools and tricks to put under your hat, Ken.
            Files and scrapers are also abrassives.
ID:	174262 Click image for larger version
              • 13728
              #1866
              • Ken_NJ
                • Sep 2014
                • 992
                #1867
                David, how long do you wait to remove the masking after painting? I've seen where paint on the model is sometimes removed with the masking. It may take days for paint to fully cure and harden. Would it be better to remove the tape while the paint is still pliable and uncured?
                Or does not not even matter?
                  • 13728
                  #1868
                  What matters -- and negates your remove the masking before/after the paint dries question -- is that the models surface is clean, freshly abraded, scrubbed down, and degreased with an appropriate solvent before any glue, filler, putty, paint, or clear coat goes down.
                  Once you handle the model with your scummy, oily, greasy, smelly paws it is contaminated with what is, in essence, a release/masking agent that must be removed before applying any of the above mediums. If you don't, the primer won't adhere properly to the model. And this applies to the later overcoats as well.
                    • 1596
                    #1869
                    What is the difference between obsession and perfection?
                      • 1596
                      #1870
                      I believe David Merriman has his second wind.
                        • 13728
                        #1871
                        Little. Can't have one without the other.
                          • 13728
                          #1872
                          • Ken_NJ
                            • Sep 2014
                            • 992
                            #1873
                            I don't see you using that fine line tape. Why not? I have the blue which is flexible. And the brown which is good for straight runs. The fine line tape does give a nice sharp edge. The painters tape is certainly great for custom curves where fine line tape will not work.
                              • 13728
                              #1874
                              Why buy that pricy thin stuff when you can easily strip your own to make tight radius capable lengths of masking tape.
                              The Magnificent​
                                • 3544
                                #1875
                                Has anybody done a Spindrift RC sub?
                                Guess it'll just be a redux of the VTTBOTS Flying Sub.
