today's work
    • 13988
    #1876
      • 13988
      #1877
        • 13988
        #1878
          Dave,
          how in the world do you cut the painter tape strips so precisely?
            • 13988
            #1880
            Originally posted by Das Boot
            Dave,
            With a straight-edge and new #11 knife blade. Duh!
            You first de-tack the low-stick 'blue' painters masking tape by pre-loading it with lint from your shirt or pants (to further reduce its tack); stick it to a plastic sheet cutting board; and hack away.
            A compass cutter is another useful mask-cutting tool. As are brass tube punches.
              I know you use a hobby knife, peckerhead. Thanks for the lesson.
                • 13988
                #1882
                  • 3761
                  #1883
                  Last set of photos.....what are you doing? No, I know what you are doing you are marking waterline, but why? It is taped correctly, yes? Isn't the hull already split? So many questions.....Love learning from you.
                    • 13988
                    #1884
                    There are usually -- for boats that have spent time tied up in waters of varied specific gravity, mineral content and varied temperatures -- what appears to be one or more minor bands of discoloration beneath the boats designed waterline. What you see in those shots you referred too is the laying down of a pencil fantom waterline, later used to guide me as I brush and spray-paint these band(s) of discoloration. I call the scheme: 'the parfait effect'; the stratification of various forms of marine fouling.
                      Just a short note to thank you again for your second go around on the concept 2 Seaview presentation on Dive Tribe today. It was very informative, and the concept 2 model lends itself for a good design for a pool as a surface runner. I really prefer single motor submarines over dual motors. I may have to give in on this and build the Seaview with dual motors.
                      Thanks again David,
                      "Firemen can stand the heat."
                        • 13988
                        #1886
                          • 13988
                          #1887
                          • Davjacva
                            • Nov 2022
                            • 408
                            #1888
                            Took a metal-impregnated rubber disk to clean up the solder and made short work of clean up. Pickled it, then primered with the latest Dupont automotive primer. Finished with Tamiya acrylics, dry-brushed a metalizer, three coats of flat clear coat. Hope this one will hold up. Photos of course are out of order. Figure it out.Click image for larger version
ID:	175626 Click image for larger version
ID:	175627 Click image for larger version
ID:	175628 Click image for larger version
ID:	175629 Click image for larger version
ID:	175630 Click image for larger version
                              • 13988
                              #1889
                              Hey!... dumb-ass: your pictures are out of order!
                              • Davjacva
                                • Nov 2022
                                • 408
                                #1890
                                Makin' sure you're not slackin' over there...or sleepin'. There'll be a test later. See you in the AM.
