today's work
    • 3643
    #1126
    Originally posted by James Wittaker
    you can weigh the mass of all the plastic kits above the waterline yourself and then make an estimate to get a reasonable ballast water volume.
    You can do it yourself and it is not difficult.
    Thank you. I will pass on this information.
      • 13896
      #1127
        • 3643
        #1128
        How are the shafts secured to the control surfaces?
          • Oct 2017
          • 1032
          #1129
          How do you secure your diveplanes to the shaft, redboat219?
          Friction grip, grub screws, pins, CA glue?
          Why do you ALWAYS ask questions instead of giving some insight on your own.
          It is all in the pictures! I mean, David M. is giving us a first hand fotostory about how to convert that sub to rc.
          Go get that kit and make it so!
          • James Wittaker
            • Oct 2021
            • 67
            #1130
            We can't say that asking questions is bad, what we care about is whether these questions are valuable. If you ask a question that the teacher has repeated hundreds of times in school, the teacher will be very annoyed. From 2005 to now Mr. Merriman has posted thousands of pictures on the forum, showing in detail various methods and techniques of making submarines. Even if some visitors to the forum who can't read English, just by studying the pictures posted by Mr. Merriman and then practicing a lot, I believe they won't ask so many questions.
              • 3643
              #1131
              What's in the picture? All I see is a brass rod that slides inside an aluminum tube with no signs of positive locking.
                • 13896
                #1132
                All will be revealed.
                  • Oct 2017
                  • 1032
                  #1133
                  Maybe the shafts are flattened at one side and connect to an inward-crimped part of the aluminum tube
                    • 13896
                    #1134
                    Right now the operating shafts are loose fits to the aluminum tubes glued within the control surfaces. A model this small does not present enough 'meat' on the control surface to make a securing set-screw a practical means of making the control surface rigid to its operating shaft. Before final assembly (long after the painting and weathering is completed, but before sea-trials) I'll dope the inside of the aluminum tube bores with some thin formula CA which will create a strong friction fit to the operating shafts. Anyway... that's the plan. Stay tuned for how that turns out.
                      • Oct 2017
                      • 1032
                      #1135
                      Hi david, i would have pm'd but your inbox is full. Did not receive your last visitor message.
                      Jörg
                      • Scott T
                        • May 2009
                        • 410
                        #1136
                        Quote: "I'll dope the inside of the aluminum tube bores with some thin formula CA which will create a strong friction fit to the operating shafts."
                        Nice!
                        I always thought a friction fit would work. My thought was to use silicone. And if the planes/rudders got bumped it would allow it to move. Then could be twisted back into position.
                        No actual tests have been done. So like the news slingers we will not verify if its true.
                          • 13896
                          #1137
                          Nice!
                          I've tried that but found that once 'broken' the silicon bond (former bond) just let the control surface to rotate wild to the operating shaft. Hense my upcoming attempt with the CA.
                          (And while trying to nap a few hours ago I thought up a scheme to get the operating shaft out of the aluminum tube if I had to take something apart. It came to me: make the operating shaft a tube instead of a rod and if I have to weaken the CA for extraction, just heat a brass rod that will fit the tube. Heat the rod externally to a red heat, then jam into the tube (operating shaft) and let the conducted heat bust the CA bond between operating shaft and aluminum tube).
                          Damn... I'm good!
                            • 1628
                            #1138
                            All this for a ChiCom boat. Meh. (I ended up getting one).
                              • 13896
                              #1139
                                • 13896
                                #1140
