today's work
    Any advice on using "industrial grade" paint on styrene models, some model builders claim the solvent used in these are too "hot" than those used in hobby grade stuffs that the plastic becomes brittle and eventually crack.
      Acrylic paint is the norm.
        For top coat and weathering.
        David recommends using decanted rattle can paint for base coats- more resilient.
        Guess it's ok for GRP hulls but how about styrene hulls like the Bronco Type XXIII or Revell Skipjack?
        • neitosub
          • Nov 2021
          • 163
          #1144
          I used automotive grade primer on my Type II build, the hull is made from styrene. I haven’t noticed any cracking or warping. Always test on a scrap piece first with whatever paint you want to use.
          • wlambing
            • Nov 2020
            • 399
            #1145
            Automotive primers work great on the styrene hulls! Been using them for years on various plastics with no problems encountered. Since Rustoleum bought out everybody else (why no Antri-Trust action by US gov't????), everything has been reformulated to be less harmful to the environment, and less nasty for styrene. Shame too, as the primer colors have been changed and are no longer correct for our boats, close, but not quite!!!
              Nice to know. Thanks.
                • 13995
                #1147
                  • 13995
                  #1148
                    Hi David,
                    Looking at your gap filling process, you are applying masking tape as a means to dam up the Bondo to form the gap filler. After the Bondo has cured you pull away the tape and shape the Bondo, and then apply thin CA to the cured Bondo? I assume this adds more strength to the Bondo joint?
                    David! Now that I sort of have my feet wet in this hobby, I am going to spend some real learning time by going through all 77 pages of your "Todays Work" blog and read all your information and study every photo you have put up. I truly want to get into the real nuts and bolts of this hobby! I do have a somewhat firm foundation (2.5 years) of building submarines and some primitive scratch built WTC, but now I would like to really learn more about it.
                    Again, I want to thank you for all the help and information that you provide to all of us in this hobby!
                      • 1112
                      #1150
                      What are those indexing lips made from? Cannot be injected styrene for you dont use a welding glue...
                      i would NEVER use CA alone to attach them to the hull. I believe the adhesion beeing too brittle.
                      please enlighten me
                      Jörg
                        • 13995
                        #1151
                        please enlighten me
                        Jörg
                        Good observation. The indexing tabs/lips are cast polyurethane, which necessitates the use of an adhesive bond over the preferred welding a cohesive provides.
                          • 1112
                          #1152
                          And you do not anything else but CA?
                            • 13995
                            #1153
                            Correct.
                            Cyanoacrylate is best suited for this task -- it is fast setting; easily broken away (fails readily in shear) for re-alignment/replacement; and is adequate for the job of bonding dissimilar materials which are not chemically able to fuse together at room temperature.
                              • 13995
                              #1154
                                Looks like you're using a trimmed down scimitar prop from either a 1/96 German Type 212/214 or a 636 Kilo.
                                Is the prop meant for the 1/144th 636 version of the Kilo too small for use here?
