    • 3613
    #91
    Nice operating system.
    The torpedo doors are closed when the pin on the turntable is in 2 o'clock clock position and open in the 6 o'clock position. Just add another pin for the other door. But only one door will be open at one time.
    Think you have to open up or lengthen the forward portion of the internal guide rails to the length of the entire door to enable the turntable to rotate in opposite directions.
    From above with both doors closed the operating pins on the turntable would be in the 9 and 3 o'clock position respectively. If you wamt to open say the starboard door you rotate the turntable clockwise 90° so that the S'board pin would be in the 6 o' clock position. The pin on the port tube now goes to the near 12 o'clock position. Two opposing magnets on the inside of the door would ensure the adjacent door remains closed
      • 1602
      #92
      Romel,
      You're getting warm on the door mechanism, try again.
      As for using magnets to keep the doors shut, once my torpedo is launched it has to come near the torpedo door, which holds a magnet in your theory, hmmmmm, my torps are magnetic activated, so it will shut down my torpedo.
      Must be a funny sight, two torpedo's halfway out of your type XXIII, and then running the gauntlett for evading depth charges, a Uboot captain's wet dream.
      The work will continue at the Skunkworks, be patient.
      • modelnut
        • Jun 2011
        • 140
        #93
        I have the doors installed in my static build of this kit. It turns out that with the magnets in place you can't open both doors at once wide enough to release both torpedoes. Very Angry
        I'm was planning on adding the inner tube doors and rigging up a system to pull both doors open and lock them in place. But with those magnets preventing that I will have to rethink this. I don't think moving the magnets further aft along the door will work. The strain of fighting the magnets might be too much for the styrene either in the long run or the short run.
        I wonder. Will foam keep its spring after repeated use? Maybe a gentle spring . . . Oy.
        - Leelan
        • modelnut
          • Jun 2011
          • 140
          #94
          Almost forgot! There is a bit of instructions not included with the kit. They are only online should you be looking hard enough to find them. They have to do with the tower running light assemblies:
          - Leelan
            • 13831
            #95
            - Leelan
            Just get your weapons to work. Sweat the little details (practical shutter-doors) later.
            Crawl-walk-run-fly. In that order.
            • Scott T
              • May 2009
              • 409
              #96
              Could you get a little extra door movement by drilling a hole through the door and glueing the magnets
              flush with the outside surface?
              Spring? How about using a nyon wire tie as a spring. It won't rust.
              Sorry we are just filling the time till we get some more of Manfreds amazing build.
                • 1602
                #97
                All those idea's with using a spring, T-rap or foam won't work, your servo's can't pull that much force, as for the room for shooting both torpedo's, i have to open up the door across the centerline of my boat to get enough clearance for my torpedo, there is simply not enough room.
                So molesting your doors to get the magnet lower won't help, i tested this configuration with different postions of the magnets on the doors, if you place the magnet more into the direction of the tube, the force to keep the door shut will be too less, so that's a bummer too.
                For now i'm refining the design with good results, most time consuming is testing, rebuilding, testing, rebuilding, testing, etc, i allready had my eureka moments, but you guys have to wait for the results, i've got my goldplated !!!!!! parts from the shop, have to secure them first inside the safe.
                • goshawk823
                  • Oct 2010
                  • 262
                  #98
                  damn tease!!!
                    • 1602
                    #99
                    NEWS FLASH!!!!, NEWS FLASH!!!!!!!,
                    I managed to get into the highly secured development area, and could take some pics before security discovered me,
                    As i can analyse from this picture they use a double disk to get the doors open.
                    They used two rods to get independent action, O boy i gotta run !!!!!!, i hear the bloodhounds!!!!!, more to be followed.
                      • 3613
                      #100
                      Why not cut 2 grooves through the PCB like this, ( ). Much simpler...
                        • 1602
                        #101
                        Romel,
                        It seems simpler, but it's not going to work that way, there is not enough travel to open the doors completely across the centerline, the problem with the Bronco XXIII is, they placed the tubes near the centerline, more ideal would be a position against the outer hull parts, i've build it this way at my type VII and type XVIIb, giving me more clearance for the torpedo's, and lesser motion at the doors.
                        Modyfing the Bronco in such way would create more work than it's worth the time, even when you've done that, you still have to solve the mechanics to open the doors.
                        • goshawk823
                          • Oct 2010
                          • 262
                          #102
                          Manfred-
                          Wwhat about modifying the bulkhead that holds the tubes themselves? Could you split the bulkhead down the center, insert a section of styrene/plasticard and move the tubes closer to the side of the hull?
                          -Sam
                            • 1602
                            #103
                            Sam,
                            Like you mentioned, the best solution would be, rebuilding both bulkheads to bring the tubes near the outer hull, i stick to the position provided by Bronco, only disadvantage is, i can only give a snapshot each, instead of firing both, for me that won't be a problem.
                            It's way too much effort to rebuild those tubes, only with the goal to fire both torpedo's at once, i rather put more time in getting this baby turned into a working rc sub.
                            • goshawk823
                              • Oct 2010
                              • 262
                              #104
                              Sam,
                              Manfred-
                              I thought you could not fire the torpedo at all with the shutter opening you had. I misunderstood...
                                • 1602
                                #105
                                Last few weeks i had another project to be made, She Who Must Be Obeyed had gotten from a friend some little stone guys, project Emperor Li was born.
                                I'll show you guys the results,
                                This i like her the most, laying on the ground at my feet, admiring my God devine work.
                                I was inspired by pictures from those guys standing inside their dugged up trenches, and decided to give it a try to replicate it.
                                Those trenches are made from one piece styrodure high density foam, and cutted into the desired shapes, given a shower of real sand and little rocks from the backside garden, used simple white wood glue to keep all the stuff at their places.
                                In the early days i've made more diorama's, but i was a bit rusty on this one, She Who Must Be Obeyed is pleased, so i can finally get back to the Skunk Works for some serious stuff.
                                Within a few weeks there is the annual meeting overhere, so all boats have to be serviced and ready to drive, busy times ahead.
