    • 1651
    #76
    It's my pleasure Sam,
    Taking different approaches create problems on their own, if my approach of using the vertical split works, it can also be done by other people, unfortunally i'm not into making commercial molds, so duplicating the bulkheads will be something people have to do on their own, this fact leaves me thinking to start learning pouring some resin.
      • 1651
      #77
      Skunkworks is running at topspeed, today i tagged the rear unit with CA, this step allows me to give a little demonstration how things work in the real live, enjoy the vid.
      • goshawk823
        • Oct 2010
        • 262
        #78
        that is pretty slick, Manfred. nice, clean break area, and once you've got your SD aligned, it looks like it's a simple fit.
        how do you keep the prop shaft in the SD and the rear shaft to the propeller coupled tightly enough to prevent one shaft spinning without the other (with such a simple connection)?
          • 1651
          #79
          Thanks Sam,
          It's becoming even more slick when you get the hang of it, after making the vid i seperated the boat a few times more for practice, once you get more experience in doing this you can take this baby apart in a few seconds.
          Making the connection between the SD and the proplsion shaft was tricky, at first i wanted to use a magnet, but i went for the mechanical way, i'll try to explain.
          If you look at the shaft on the SD you can see there is a piece grinded away, giving you a step.
          At this picture the connection is made between the SD and the shaft with the propellor, the brass connector has on the SD side a opposite grinded step inside as well, actually the same shape as on the SD shaft, placed at this position it will interlock with the shaft from the SD, both halves will unite as one when placed together.
          The brass connector itself is locked onto the propellorshaft with two grubscrews, one near the SD and another one near the brass bearing, it's securing the connector from both sides on the propellor shaft, once you pull out the SD, the connector will stay at it's place complete with the propellor shaft.
          Making this special connector took some time to measure up, and it took some more time on the lathe to turn it to my specs.
            • 3758
            #80
            Manfred,
            Just thinking this through, and I love what you have done, would there be a chance if you needed to do an emergency reverse that the forces involved would separate the halves? you could place a simple pin in to prevent a disconnect and not destroy the easy access.
              • 1651
              #81
              Tom,
              I did some testing after your remark, you need to pull 1,8 kg of force to get the hull parts seperated, overall weight of the sub at this moment is 1,38 kg.
              When doing this test the SD did not came out of the back hullpart, which is logical, the SD itself is connected by two other magnets on the steeringrods, i still have to add three magnetical connections in the front part, the steering of the front divingplanes and the launchtubes.
              All in all, when completed, both halves will be held together by a total number of 9 pair of magnets, i'll probably repeat this test after i've placed those connections simply to see what the outcome will be, i'm not really afraid seperation will happen after a emergency reverse.
              • goshawk823
                • Oct 2010
                • 262
                #82
                Originally posted by MFR1964
                Thanks Sam,
                I see it Manfred. That's how I thought you would have to do it. Make a "key" on each side of the shaft, and place a "cover" it so that it doesn't get sloppy...
                All you need to do (as I saw in your video) was rotate the prop to make sure the "keys" match.
                I'm looking forward to seeing what you are going to do for the torpedoes...
                thanks!
                Sam
                  • 2641
                  #83
                  Nice conversion on this boat.
                  Can't help but think you're going to learn a few new swear words if something goes in the stern of the boat mind you.
                    • 3758
                    #84
                    Tom,
                    O.K. that is great! Can you teach me how you figured it out? I need to learn more!
                      • 1651
                      #85
                      Sam,
                      It had to be a simple connection and yet relaible too, the launchers will be indeed the next chapter, they allready exsists in the raw, first have some glueing to do before i start with those, one step at the time, be patient.
                      Andy,
                      Those new swearwords i've allready learned during this build, i will close up both halves only after some rigurous testing, for now tape will hold her together.
                      Tom,
                      I've used a small portable electronic scale weight, you can attach objects to it by hanging them on the hook, i've attached the hook to the frontpart and started to pull untill both halves seperated, the peak weight was registred on the scale, giving me a readout of 1,8 kg pullingforce.
                      Today i've changed the positions of the magnets, that means, lesser material between the magnets, now i need to pull a wopping 5,5 kg to get both halves seperated, that should do the trick.
                      Opening up procedure is easy, with the boat on the stand you gently try to break the backbone by forcing both far ends down, this movement will seperate both halves.
                        • 3758
                        #86
                        Manfred,
                        i tend to over think and miss the simple answer. Using a scale and pulling until it separates is a simple answer. Here I was thinking there was a mathematical formula. Lesson learned, thank you very much.
                        tom
                          • 1651
                          #87
                          This week i ordered some stuff from the webshop, awaiting the stuff to be delivered i started with building up the launchers, and found a simple solution for opening the torpedo doors.
                          Building the launchers was a fairly straight job, i allready had made some components, for now everything is secured by CA, just in case i have to adjust things, i can break it free easely.
                          Making the doors work was a different story, first i replaced the plastic hinge for a more robust copper tube.
                          Lined out the door to get the best fit.
                          This is my solution for opening the doors, with my other subs they work with a spring and wires, since you can't get inside anymore i had to design a more robust system, which will be using low maintenance, and limited moving parts.
                          By turning on the shaft, which is connected to the circel, the little rod will pull the door open, in closed situation this pin will keep the door locked at it's place.
                          Shuffed in one of my electric torps, to test if there is enough clearance, i have to open up the door just across the centerline.
                          A view from the front, as you can see there is enough room for the torpedo to get out of the launcher, to get this much room i had to place the hinge as far as possible on the door.
                          For now everything is build raw, i do this each time, first make a testcase, try it, and make the final version, still a lot of work for the Skunkworks.
                            • 13982
                            #88
                            Slick!!!! I hate you!
                              • 1651
                              #89
                              My sweet revenge for my lost fortune for buying your stuff, hahahahahah
                                • 13982
                                #90
                                Touche, sir!
