    Nice Job Manfred! This thread is encouraging me to RC mine, even though I dont care for Subdrivers smaller than 3" in Diameter.
      • 1587
      #242
      Thanks Mark,
      A 2,5 SD isn't that bad, i'm more used to my roomy dryhulls boats, which reminds me about the type XVIIb, hmmmm, more work for inside the shop.
      Getting her in the open water will take some more time, i wonder if i encounted the same troubles as David has with his XXIII, i do have some things on the shelf to encounter that pitchdown issue.
      • Peter W
        • May 2011
        • 511
        #243
        Ah, how cute a baby Uboat with water wings. Does look good in the water Manfred.
        Peter
          • 1587
          #244
          Yep, you gotta learn them to swim, she will drown without the water wings, oh boy where getting fuzzy!!!
            • 1587
            #245
            Last few days some hair raising moments, having the vertical split is a pain in the butt, i managed to get those chuncks of foam in, had to split them in more usable parts,
            Had to cut away the lower part of the foam, yet again i have to add more lead for the next session, because the captain has serious problems with staying at his post inside the conningtower.
            Using the "snap on" connection did force me to fiddle the foam around my SD, it's a lot more work when using the traditional waterline cut, hopefully the last arrow i've got to dodge.
            I guess it will take another few sessions to get her right, noticed some issue's with my rudder and charging points inside the SD, that can be fixed when the glue is drying at the next try to stuff more foam in.
              I think that you thrive on challenges Mr. Manfred. If it was easy, youd get sick of it.
                • 1587
                #247
                Mark,
                I fear that's true, only the slow part of getting this done is annoying me, luckely it's not easy, it would turn David into a millionair!!, that would really suck!!!
                  • 1587
                  #248
                  There's good news, and bad news.
                  First the good news, i've got me a new job, the bad news is, less time to build on the XXIII, making long days now, i did manage to get some progress on the rudder issue and working torpedotubes, love the design Simon made, techno porn of the first order.
                  As for my design, i made a new mark III version, which is in the final trails of tinkering, next weekend i'll make some pics, or a vid to show the progress, back to the cave !!!
                    • 3693
                    #249
                    Congratulations! I am happy that you are working again! We can wait for updates!
                      • 1587
                      #250
                      Sorry for my late respons Tom, my job is sucking away most of my free time.
                      Now i can show what is going on inside the shop, i decided to scrap the first design of the torpedo tubes, had two problems, the way of connecting the triggerbars to the sliding rods gave to much problems.
                      And the space, left by the open torpedo doors, jammed now and then my torps, had to find a proper solution.
                      First a pic of the completed new design, as you can see, i made some changes with the bulkheads, had to remake the one on the right.
                      To prefent the jamming and get some more room i placed the tubes at the end slightly inwards, not scale like, but i have to get a comprimise for running torps.
                      The front bulkhead i used at the same position, only enlarged the holes to push the tubes through, had to remove the ball locks for this.
                      Took the old design of my type VII to keep the torps at their positions, simple and effective.
                      The sliding magnets to start up my torps, made a thin copper bracket to support them.
                      Redesigning the complete setting resulted in a simple way to connect the sliding bars to my trigger bars, used carbon bars for smoother sliding action.
                      Remaking and replacing the rear bulkhead gave room for this contraption, it will lock the tubes at the end, and still allows water to entry freely.
                      Getting the tubes pointed slightly outwards solved for me the jamming problem, as long as the hull is closed, nobody will know, unless you guys tell them.
                      • solosub
                        • 51
                        #251
                        Hi Manfred :)
                        very good job !
                        Laurent
                        www.scalesub.com
                        French RC submarine forum
                          • 1587
                          #252
                          Thanks Laurent,
                          Due to my new job the work on the XXIII is on hold, next few weeks i'll scare away the spiders from the cave, and finish up the torpedo tubes, then she will be ready to get her final trimming session.
                          From Tom his video i know she will be a good runner, if the tempartures stay as they are, i hope to get my testrun soon.
                            • 1587
                            #253
                            Flipped on the lights inside the cave, and scared away the spiders, this baby has to be ready before next spring.
                            First something that was a bit annoying for me, getting the battery pack out each time for charging, made me go out of my mind, so a better solution had to be made, placed a small bracket from styrene with some homemade brass loading points, this will ease my workload.
                            The launchtubes are almost ready, all parts glued down, have to place them back inside the hull, tinker the magnets and shutters, so i can try some dry and wet testruns.
                            For now i'm also collecting details about the inside of the conningtower, Bronco did offer a good base, but not good enough for me, i want some more details.
                            • crazygary
                              • Sep 2012
                              • 610
                              #254
                              Hello, Manfred!!
                              Very interesting bit of engineering with regard to your battery pack "issue"!
                              I would appreciate if you could go in to detail as to how it will work!
                              I have an idea, but not absolutely sure. Would it have anything to do with connections being
                              made involving an end cap??
                              Hmmm!! The possibilities are endless if that is the case!!
                              Great looking torpedo tubes, also!! I like them a lot!!
                                • 13792
                                #255
                                OK ... I gotta ask, Manfred:
                                What's with the little conformal tank? SAS induction sump? Trim tank? Sanitary tank for the crew? What!!???
