My Projects
    • Jan 2020
    • 1028
    #61
    Youtube video of mechanics:
      • 13838
      #62
      Good, solid work there, but a bit too Rube Goldbergish for my taste; a simple two-yoke arrangement would have kept that linkage simple. Even in a tight pool, that SKIPJACK will turn just fine with the scale rudders.
        • Jan 2020
        • 1028
        #63
        Thanks David!
          • Jan 2020
          • 1028
          #64
          Video of Sub
            • Jan 2020
            • 1028
            #65
            Any thoughts on how much original trimming ballast I should start with?
              • 13838
              #66
              1.5 - 2 lbs.
                • Jan 2020
                • 1028
                #67
                1.5 - 2 lbs.
                Thank you Sir!
                  • Jan 2020
                  • 1028
                  #68
                  How does one sleeve a 3/16" bore prop for a 3MM driveshaft?
                    • 13838
                    #69
                    By abandoning the evil, European Standards inflicted on this country by henchmen of the Dark Forces. Embrace Her Majesties Imperial standards of measurements, and always work in the Light.
                    Metric sucks!
                    The Horrible
                      • Jan 2020
                      • 1028
                      #70
                      David, totally agree, Bob has a suitable Skipjack prop with 3/16" bore, I need 3MM bore
                        • Oct 2017
                        • 1016
                        #71
                        I join the dark side
                          • Jan 2020
                          • 1028
                          #72
                          Help!
                          Ok, trimming.
                          Surface trim:
                          Needs to sit higher
                          Submerged trim:
                          Needs to sit lower
                          Surface trim
                          Submerged trim:
                            • 13838
                            #73
                            Any foam mounted above water line lowered so that it is situated below waterline. add more fixed ballast weight and compensate with additional foam as required.
                              • Jan 2020
                              • 1028
                              #74
                              David, thanks! will do
                                • 2016
                                #75
                                Trimming Your Submarine: https://www.youtube.com/watch?v=6rFVx8uLmas
                                Sleeving your Propeller: https://www.youtube.com/watch?v=EQqhE9_r5ag
