    • Jan 2020
    • 1027
    #106
    24ghz Click image for larger version
ID:	175394 Antenna Fabrication
      • Jan 2020
      • 1027
      #107
      Air tube goes in here, the hole is the vent Click image for larger version
        • Jan 2020
        • 1027
        #108
        Antennas, and cleaned up Resin Rudder and Dive Planes
          • Jan 2020
          • 1027
          #109
          Redesigned Antennas, brass rods to be black
            • Jan 2020
            • 1027
            #110
            Moving along....
              • 3534
              #111
              If one were to use the kits appendages (hollow) would it be advisable to either fill the insides with resin, drill holes to make them freeflooding or use them as is?
                • Oct 2017
                • 999
                #112
                Another question...
                Redboat, you need a 3d-printer, print out a beginners model with proof electronic outfitting and have fun with it.
                who cares if those parts work? You want a model for the pool, go for plastic and take care not to crash into something. You want a model for the pond, you go for metal and prepare for easy replacement since the next piece of floating wood in the way MIGHT actually be tougher than expected.
                buy that kit, build it to your specs and try, whether one should fill in resin, drill holes or use them not at all. Thats an injected kit, not titanium. What could one expect?
                You need to build, not to ask for every single detail and how this and that could be done. Leave that tiny KILO and aim at a larger size thats better to handle. ROBBE Seawolf and alike.ugly, yes, but with one of those you'd had a model in the water years ago.
                Gathering informations will not get you closer to the pond...
                  • Jan 2020
                  • 1027
                  #113
                  I only run my Subs in my pool so I am designing a Rudder Extension for agility
ID:	175468 Click image for larger version
Name:	Image 10-29-23 at 9.05 AM.jpg
ID:	175469 Click image for larger version
                    • Jan 2020
                    • 1027
                    #114
                    Redesigning Binoculars
Name:	Image 10-29-23 at 10.50 AM.jpg
                      • Jan 2020
                      • 1027
                      #115
                      New Binoculars
                        • Jan 2020
                        • 1027
                        #116
                        To vent the free-flooding hull and reduce displacement of the above waterline structures.
                        David, are the "planks" (what are they called Sir?) steel or wood? What does a white stripe signify? Yellow is training? Click image for larger version  Name:	Image 9-28-23 at 3.00 PM.jpg Views:	0 Size:	56.5 KB ID:	175516
                        • DrSchmidt
                          • Apr 2014
                          • 1340
                          #117
                          Actually the wooden deck was only used in the habor. Underway they were removed....
                            • Jan 2020
                            • 1027
                            #118
                            David, are the "planks" (what are they called Sir?) steel or wood? Not sure how to paint & weather them? In your photos looks like you painted grey and added rust? What does a white stripe signify? Yellow is training? Anybody know how I should proceed?
                              • 13718
                              #119
                              Wood. Tan colored, with variations of tan to signify different sources of planking.
                              White status bands on the sail appears to be a research mistake on the part of Bronco. I have it on good authority (thanks, Manfred), that the sail vertical and horizontal markigns, which were yellow, signified a boat undergoing work-up for eventual operational use. Using that logic -- the boat would not sortie far from base, and not for extended periods of time -- I assumed the portable decking would likely have remained in place on some of the training units. Just a guess -- I so wanted that decking in place to hide the many vent holes I drilled atop the models hull to vent the boat as it transitioned from submerged to surface trim and back.
                                • Jan 2020
                                • 1027
                                #120
                                Thanks David, I also have vent holes under where they go!
