jims Tyhpoon TK-208 build
  • deepseadiver
    • 296
    #76
    installation of my bow thruster system. I'm planning to put detail on this sub other have not done at least not yet
    • deepseadiver
      • 296
      #77
      thruster jets glued and sanded smooth while i had to do some rework on some of the scribe . will work on it more after primer is placed on. some day some time in the future I don't know! LOL.
      • deepseadiver
        • 296
        #78
        dive plans work great all different angels
        • deepseadiver
          • 296
          #79
          one more angel
          • deepseadiver
            • 296
            #80
ID:	129660Click image for larger version  Name:	2q.jpg Views:	1 Size:	432.0 KB ID:	129659 tail fin light wire glued into the top out of the way and both brass push rods are in works smooth and perfect.
            • deepseadiver
              • 296
              #81
              fit perfect don't touch anything precession David im good
              • deepseadiver
                • 296
                #82
                motor have been installed next to place the drive shafts in next and control rods linked up to servos to work rudder tail fins all that fun stuff
                  • 13948
                  #83
                  points awarded for hitting back and sticking with it.
                  • Mankster
                    • 41
                    #84
                    I did it a little different for those push rods. I used regular servo horns. Also I found I need to reinforce the bend on the push rods to stop them flexing - very important for the rear dive plane servo for good depth keeping.
                    • deepseadiver
                      • 296
                      #85
                      Hi thanks for the tip I really like what you did right on. Good stuff to know picture explain what you did very well
                      if I see any flex I may do the same . So far it looks solid when I work the servo between push rod and rudder.
                      Jim :)
                        • 2041
                        #86
                        Alrighty, people. It seems there is a truce, albeit a tenuous one. I'm cleaning house in this thread, removing the off-topic diatribe for future posterity.
                        • deepseadiver
                          • 296
                          #87
                          drive shaft installed work smooth
                          • deepseadiver
                            • 296
                            #88
                            something I made from scratch. question do you know what there for I do ?
                            • deepseadiver
                              • 296
                              #89
                              old vintage photos of this beast 48,000 tonnes built between1976-1986
                              • deepseadiver
                                • 296
                                #90
                                scratch built part.
