    Yes, it can help pay for the build so you can have funds also for the next one.
      • 3757
      #242
      It never pays to play.
      • crazygary
        • Sep 2012
        • 610
        #243
        "Sin City" is a fun place!! Some seriously crazy-ass people out there in the desert!! Hah!!
        I fit right in!!
        Ya just gotta "know when to hold 'em, know when to fold 'em..."
        (Thanks Kenny!!)
        CG
          • 3757
          #244
          Decided to go with colored glass versus colored bulb. So painted clear red and clear green on the light cover.
Name:	Bronco Type 23_302.jpg
          Then I tried something silly. Could I drill a tiny hole on the edge of a plastic tube? then do it eight more times? and make them even?
          The short answer is yes, sorta, and no.
          I drilled .031" hole on the edge of the 5/16" plastic tube. id that eight time, but did not get them even. Stuck lengths of .030" rods in and glued them in.
Name:	Bronco Type 23_303.jpg
          Let it set completely. Then trimmed the rods and sanded the bolts as well as thinned the base.
Name:	Bronco Type 23_304.jpg
          It will work for me.
          • crazygary
            • Sep 2012
            • 610
            #245
            Looks like a flange to me!!
            Good trick, Tom!!
            Gotta remember that one!
            CG
              If you used heat stretched styrene rods with hexagonal cross section you'll get bolt heads.
              • crazygary
                • Sep 2012
                • 610
                #247
                Sounds plausible, redboat219!!
                Good call!
                Scaling them to what you need may be a little problematic. But, the trial-and-error process
                would certainly give you some useable data!!
                Might have to try that just for fun!!
                CG
                • crazygary
                  • Sep 2012
                  • 610
                  #248
                  Wow!!
                  I just took a quick look at the Plastruct, Inc. offering of hexagonal rod,
                  and they're showing it available as small as .5mm. Who'da thunk it!!??
                  I'd like to see their extrusion setup for something that small!! Hah!!
                  CG
                    Wow!!
                    CG
                    In that case it's just a matter of slicing off sections with a razor blade
                    • crazygary
                      • Sep 2012
                      • 610
                      #250
                      BTW, Tom!!
                      Cool idea with regard to your lenses!
                      You "Da Man"!!
                      CG
                        • 3757
                        #251
                        Thank you Gary!
Name:	Bronco Type 23_305.jpg
                        Began by melting the tip under a flame. I quickly saw that was not going to work. Then I used a thick CA to round out the tip, it seemed to catch the melted part and make a nice bulb. Then this morning I needed to dip it in the thin because of a bubble. O.K. slot machine handle set aside to dry.
                        Installed railing and antenna base. Broke external railing (twice). I just know that these details I am doing might last a patrol or two, but probably not much more. Antennas will disappear, poles will break, but for one patrol it will look good.
Name:	Bronco Type 23_306.jpg
Name:	Bronco Type 23_307.jpg
                        • alad61
                          • Jan 2012
                          • 476
                          #252
                          Tom I know I haven't commented much on your XXIII but I am really enjoying what you are doing plus I get a kick from the tips n tricks you've done to date.
                          Cheers,
                          Alec.
                          Reality is but a dream...
                          But to dream is a reality
                            • 3757
                            #253
                            Alec, Thank you, I am glad these postings are of value and I appreciate your encouragement.
                            Earlier I asked about a white light for navigation on the Type XXIII. I saw a model of a Type XXIII with it on the periscope and wanted proof the Type XXIII used it. A gentleman by the name ofMichael shared this photo, but said it was for a Type VIIc (U-281)
Name:	Bronco Type 23_308.jpg
                            That is cool, but then he also shared this one (U-2360):
Name:	Bronco Type 23_309.jpg
                            Bingo!
                            I also read that the oval depicted on the Bronco model's sail (aft and bottom) was a housing for a light. I will try to find that source again.
                              • 3757
                              #254
                              The oval opening is not a light. Michael posted "According to the drawing in VOZM it's a "Tauklüse", means hawse for ropes" . That is why you check your sources.
                              so the decision is whether the periscope mounting or the unique light housing on the upper aft conning tower.
                              Speaking of checking your sources, the drawings in the Bronco instructions are not accurate. I can not find a photo that shows the black waterline being used and found that ships use them, but u-boats never did. I guess it looks pretty.
                                • 1651
                                #255
                                Ahhhhh, you're now a official member of the dark side, lovely details, a feast for my eyes, now you know why i always want to research a type of boat for a year, it will spare you the drawbacks when you discover new details.
                                Spoken about details, at the back of your peroscope protector there has to be a round floodhole, that's what i've found on researching my pictures, a minor thing, but most usefull to get away those pesty airpockets.
