Working on some weathering.
Did a little salt weathering. I had a very dark gray base layer down. Then after it was dried put some water in areas that I wanted the paint to be chipping off. Sprinkled salt on those areas and let that dry. Then sprayed a top coat over it.
Then rub the salt off.
Used the same technique on the wood planking braces.
Painted a mixture of black and brown to simulate carbolineum (Reference used http://www.rokket.biz/modelsweb/rokket/u557/paint.shtml - finally found the source)
A little grunge between the planks.
The next step will be a dry brushing of a lighter brown on the edges and tread path. Then some rusting between the planks.
