  • Dandyfunk
    • Jun 2020
    • 12
    #121
    Thanks Rob, I will see if I can find the videos. Are the types of glues and primers for pla also somewhere on his site?
    • george
      • Dec 2010
      • 731
      #122
      Hi Dandyfunk, I sent you a private message, did you get it? Also welcome to the club.
      George
        • 1994
        #123
        The video that I did for the Astute is by far the most comprehensive. It includes step-by-step for assembly, gluing, priming, painting and coating with epoxy.
        • SteveNeill
          • 315
          #124
          Great going Rob. We watch and enjoy!
          • a1965l
            • 147
            #125
            I mounted the snorkle valve in my sail and then bolted the sail to the hull. Seems to work...
              • 3682
              #126
              Rob? Rob whom I met in Southern California?
              If so, it was the Thunder Tiger Neptune that made a connection for me.
                • 3682
                #127
                O.K. - so you were not the one in SoCal, my memory is mixing things up. Rob, then I pray our paths cross. I enjoy your passion.
                • SteveNeill
                  • 315
                  #128
                  Congrats Rob!
                  • SteveNeill
                    • 315
                    #129
                    Video next time!
                    • SteveNeill
                      • 315
                      #130
                      I can help Rob when the time comes.
                      • george
                        • Dec 2010
                        • 731
                        #131
                        Well they are meant to be used in the water. Bathroom, steam, water, gives you something to focus on when your in there.
                          • 821
                          #132
                          Any updates Rob?
                            • 821
                            #133
                            Hi Steve,
                            Got a little more building in! I put the hull together on my 3D printed Los Angeles and a first primer coat. I will be doing some internal work on the hull in order accommodate the 2.5" SD that I got from David M.
                            I also just received the fitting kit that David M. did for the Skipjack (awesome Kit) from Nautilus Drydocks, so now I can move along on the Skipjack!
                            I am also working on the Albacore, and I will get some photos of my progress on that boat. soon!
                            Good to hear. You definitely have a lot going on there. The LA is looking good! Sharp looking boat.
                            • SteveNeill
                              • 315
                              #134
                              Rob what nice eye candy. One day I'll be able to build my type 23 but customers come first.
                                • 821
                                #135
                                Awesome Rob! With the Redoutable does that make 6 subs total? That's a good fleet of boats.
