3D Printing Submariens and Sub Components
  • SteveNeill
    • 315
    #136
    Outstanding. Keep it up sailor!
      RCJetDude, I have the same setup as far as the 2.5/3/2.5. Question, your servos appear to be on the bottom of the module instead of the top. Is that correct? I’ve never seen that done before. Is it easier to do it that way for your particular boat? Thanks.
        Originally posted by rwtdiver
        While I am here I will share my first hull part on the LA Class Attack Sub! I have the stern completed. I wanted to start on the stern so that I can work on how I will install the control linkages. It's going to be fun! not much room to work with. But as they say "No pain No gain!:-))
        I will be printing this Sub from stern to bow! More coming!
        Are you by chance a ham radio op? I noticed the receiver and looks like QRP transmitters.
          Well, I’ve read and looked at all 15 pages of these builds. I can, without a doubt say, that I hate all of you. Especially you, Rob. Seriously though, I can’t paint, scratch build or play anything but a record player. You guys are a credit to the hobby. At one time I thought rc subs were dead after the unfortunate semi-demise of an organization I used to belong to. However, I see it’s stronger than ever. Rock on,
          Casey
          • SubDude
            • 825
            #140
            That is just the way it worked out for me. It could be set up either way.
              If it works then great. I looked at it too once.
                Thank you Casey,
                I have not even scratched the surface as to all there is to learn about this hobby! There are some real craftsman on this forum, and any tidbit of knowledge I have gained is a credit to these fine people and the help they have extended me along the way!!
                You a ham?
                  Thank you Casey,
                  David already has a big head, hush.
                  • frozenottsel
                    • Jun 2020
                    • 11
                    #144
                    Hello everyone, I've been lurking around this thread for a while now, but I finally decided a few weeks ago to have my try at a 3D printed submarine.
                    I modeled my own Virginia Class sub to about 1/100 scale, here's some quick pictures of the test fitting :D
Name:	1 - ojCbs2P.jpg
ID:	142120Click image for larger version
Name:	4 - dy7TseK.jpg
ID:	142119Click image for larger version
Name:	3 - tUFvLCH.jpg
                    • frozenottsel
                      • Jun 2020
                      • 11
                      #145
                      frozenottsel
                      Looks very good! Did you do your own CAD work on this Sub? If so what CAD design system are you using? My LA Class Sub was from Nautilus Drydocks and the file he has for sale! Are you going to design your own SD/WTC for this build!
                      Got to love 3D Printed Submarines!!!
                      Hello Rob,
                      Yes, I did my own cad work for this sub using SolidWorks and I do intend to design my own WTC for this build.
                      I'm super excited about how it's coming along, and I'm already beginning to imagine what else I could try my hand at :D
                      Andrew
                      • SubDude
                        • 825
                        #146
                        Interesting construction. Are the parts vacuum formed?
                        • SubDude
                          • 825
                          #147
                          I have started the LA class boat but printing it at 1/72nd scale which makes it a 5.5" beam and just over 60" long.
                          Again using PLA+. I am hoping the MSD in the Redoutable will also work in it too. I will see...
                          Steve
                          • george
                            • Dec 2010
                            • 731
                            #148
                            Is the VII C file your creation OR did you find it somewhere?
                            Thanks for sharing your build/collection.
                            • frozenottsel
                              • Jun 2020
                              • 11
                              #149
                              Update on my Virginia model.
                              Gluing is done (with exception for the tailpiece where the rudder and stern plane axles with go), hold-down screw inserts are in (note to self: in the future, design the holes for the inserts into the model, it'll be easier than drilling the holes), and I've finished a first pass of sanding :D
                              Click image for larger version  Name:	IMG_2897.jpg Views:	0 Size:	92.1 KB ID:	142486 Click image for larger version
                              Really starting to come together now :D
                              Last edited by frozenottsel; 08-02-2020, 11:58 AM. Reason: Edit: Added second (side view) picture
                              • substandard
                                • Jun 2020
                                • 34
                                #150
                                This could probably also be posted in the "Silly Questions from Newbies" but here she goes"
                                The part that bothers me about 3D printing subs with filament being what it is; is the durability in hot weather of the printed sub. (Subs are usually black - doah!).
                                What about 3D printing a sub as thin as reasonably possible and then laying up a layer or two of glass on top of it so its more durable and lasts in the sun?
                                Would that produce a durable and "good" final product?
                                For extra rigidity a glass layer could also be added on the sub inside after printing.
                                If this works it would allow for all of the benefits of 3D printing (accuracy, straight lines, less mess, less dust,less physical work etc) without a lot of the downsides of doing fiberglass molding work (making plug, crooked lines, sanding, sanding and more sanding etc)
                                What do you think?
