today's work
  • RCENGR
    • May 2025
    • 25
    #3556
    What advantage does the bellcrank give you over using direct actuation? Is just that you didn't have room to turn the servos 90 degrees in the WTC?
      • 13896
      #3557
      Yes, I could only fit these little 'microbe' sized linear servos with travel athwartship, hence the need for bell-cranks to translate the output to a longitudinal one.
        • 3644
        #3558
        Hobbyist who convert 1/64 Hotwheels/Matchbox cars use these 1.7gm servos in lieu of those linear servos..
ID:	194318 Click image for larger version
          • 13896
          #3559
          Excellent tip, Romel. I'll look into those. Thanks.
            • 13896
            #3560
              • 13896
              #3561
                • 3644
                #3562
                Why does the paint have a mottled pitted appearance?
                  • 13896
                  #3563
                  Fish-eye. Some crap got into the mix. It'll sand out. Goes away entirely after a heavy, well flattened clear-coat. Not my first rodeo. Ain't finished yet!!
                    • 3644
                    #3564
                    will make weathering easier. Marine growth and grime.
                      • 3724
                      #3565
                      David, that Albacore sail is outstanding. Truly one of your best yet.
                        • Oct 2017
                        • 1032
                        #3566
                        Wow, the Sierra looks mean! Very jealous...
                        Jörg
                          • 13896
                          #3567
                          I woke up stupid this morning. Thinking of representing that 'city crest' we see at the leading edge of one of these boats sail.
                          Some fine painting on decal film seems to be in order for the near future. Will be good to once again haunt my drafting-room upstairs. A fun departure from the usual grind of the shop.
                            • 13896
                            #3568
                            Nope. Not my work. Evil robot printed. Sent to me by Howard to be worked up into production tooling.
                              • 3644
                              #3569
                              Similar to this one? Click image for larger version
ID:	194332 Click image for larger version
                                • 13896
                                #3570
                                Exactly that one.
