today's work
  • Peter W
    • May 2011
    • 511
    #3406
    Scott Terrey/Hardrock?
    Sadly, i believe he died from his cancer last year.
    Pretty sure, although not totally, he is mentioned here if you click on his name it gives a brief obituary.
    Very sad he was always very helpful and a wonderful modeller. I have 1 of his Beluga hulls somewhere.
    Peter
      • 1109
      #3407
      Yes, thats him.
        Peter
        That's unfortunate news. He was truly a generous person.
        Thank you Scott.
          • 13991
          #3409
            • 13991
            #3410
              • 13991
              #3411
                • 13991
                #3412
                  • 13991
                  #3413
                    • 13991
                    #3414
                      • 1109
                      #3415
                      That prop arrangement is awesome! Is the stern cone intersection static or does it rotate as well?
                      Jörg
                        • 13991
                        #3416
                        Jörg
                        It rotates. I assume with the forward screw... but not sure.
                          • 13991
                          #3417
                            • 1393
                            #3418
                            You fix clear parts with super glue? That's courageous. Don't you fear that the super glue fumes cause a white fogging on the windows?
                              • 13991
                              #3419
                              You fix clear parts with super glue? That's courageous. don't you fear that the super glue fumes cause a white fogging on the windows?
                              Seems this formula of CA, packaged for the Harbor Freight company, either does not react with the 'clouding' issuer of other brands, or the chemistry of the plastic I used to vacuform the bubbles was not susceptible to that unfortunate effect. I tested on an unused bubble and after that had the confidence to employ the CA on these clear plastic parts as I secured them to the NAUTILUS wheelhouse.
                                • 13991
                                #3420
