today's work
    • 13831
    #2851
    Click image for larger version Name:	Screenshot_20250306_060410_Chrome.jpg Views:	0 Size:	69.3 KB ID:	186617
    Different patterns of vent slots, top is alternating while bottom is in rows.
    stop sweating the small ****. Work first! Rivet counting a distant second!
      • 3613
      #2852
      Remind me of the 1/15 Mk 8 SDV
      https://forum.rc-sub.com/forum/gener...004#post144004.
      Don't remember seeing videos of it running.
      Thr CB will be smaller right?
        • 784
        #2853
        Success. Size correct now. Test of second hull perfect size now dialed in perfectly for 1/32. Other parts printing proceeding. I will do some light sanding and removal of flash & coat with a primer for making surfaces perfect. Should send you mold patterns for you Dave to begin your magic in 2 weeks I expect. Sailoring on, I guess the appropriate word should be Ciao for now. lol
        Click image for larger version  Name:	CB-5-b.jpg Views:	0 Size:	50.3 KB ID:	186621
        Click image for larger version  Name:	cb-6.jpg Views:	0 Size:	57.0 KB ID:	186622
        Click image for larger version  Name:	CB-7-b.jpg Views:	0 Size:	49.9 KB ID:	186623
          • 13831
          #2854
          Good. Standing by.
            • 13831
            #2855
              • 13831
              #2856
                • 13831
                #2857
                  • Oct 2017
                  • 1013
                  #2858
                  Nice props! Whats the ALFA's scale? 1/72?
                    • 13831
                    #2859
                    The one I'm currently working on is 1/72nd. It originated in the hands of Master Craftsman, Greg Sharpe who first offered it as a GRP kit decades ago. Later the tooling was acquired by Matt Thor who did his usual magic with the glass work and issued the kit under his label. Early on with that transition I got involved by contributing 'improved' stabilizers and control surfaces, linkages, propellers, and mast detailing.
                    I'm also working up a Scale Shipyards 1/96 ALFA. It's almost done but other work has priority at the moment.
                      • 13831
                      #2860
                        • 2548
                        #2861
                        There is usually so much variation in the 1:1 boats, especially smaller craft that were generally handmade in different yards from some generic plans and often altered over their service life. A modellers can drive themselves into a padded cell trying to get it 100%. Seehund is a good example, despite construction in a form of production line no two appeared identical. In service they were subject to repair or retrofitted with updated kit, usually hastily done, and any surviving examples have often been further hacked around to repair damage or corrosion.
                          • 13831
                          #2862
                          • goshawk823
                            • Oct 2010
                            • 262
                            #2863
                            beautiful work on those masts. my 1/72 Alfa was a great running boat; I wish I would have had that hardware for the sail. It was pretty plain without it. Great stuff, David.
                              • 13831
                              #2864
                              For those looking over my shoulder: Though I've known Sam for decades, I had no idea that this Clark Kent type had a secret identity as an expert wood sculptor -- only recently did I find some of his bird work over at Facebook. His work is photo-real! Amazing stuff. Go over there and check out his work.
                              • goshawk823
                                • Oct 2010
                                • 262
                                #2865
                                Thanks for the accolades, David. I started carving birds in 1988, the same year I started building a 32nd Parallel Type VIIc. For years, I’d sell my carvings to help sustain both carving and model building hobbies.
                                Right now, I’ve got two birds, a 1/72 Type XXI and a 1/200 HMS Nelson going at the same time. :)
