today's work
    How about I stick the pointy-end of a broom-stick up my ass so I can sweep the place as I shuffle out the door?
    Okey guys, on the count of three... Click image for larger version  Name:	images (4).jpg Views:	0 Size:	69.3 KB ID:	181344
      • 13948
      #2297
      LOL (touché)
        • 13948
        #2298
          Click image for larger version  Name:	I5UOhE.jpg Views:	0 Size:	58.7 KB ID:	181402 Click image for larger version  Name:	EcNdyh.jpg Views:	0 Size:	60.9 KB ID:	181403 Click image for larger version  Name:	VH2Ax4.jpg Views:	0 Size:	59.7 KB ID:	181404 How long would these motor last before needing replacement running in lake, pond or swimming pool (chlorinated or salt)?
          Would "motor in the wet" be applicable for a 1/72 Revell Type VII or IX?
            • 13948
            #2300
            Yet to be determined.
              • Oct 2017
              • 1088
              #2301
              Very short. some nasty sound indicates need for replacement. I did that with revell models as a kid. Would not do that again.
              This is not a promising engine installation.
              Romel, you need to do practical work. Build a boat from the start and run it. Find solutions instead of asking what might work or what could work better. Trial and error it is!
              Jörg
                • 13948
                #2302
                Jörg
                As an unschooled 'practical engineer, the only way I can get a mechanism to work properly is through the process of try something and alter the arrangement till the system works as intended. Elon Musk has made popular the word 'iteration'; his method of achieving flight-qualified hardware. Same thing -- build it, run it till something breaks, fix the broken part, run it again. Keep up the process till the desired performance is achieved and call it a day. I've run these cheap ass little can motors in the wet for years. When they ****-the-bed I just pop a new one in there. I got hundreds of these little things, left over from our Caswell days.
                As for our friend, Romel. "Yeah!, what Jorg just said!"
                Dumb-Ass Torpedoman with good hands
                • ffr2608
                  • Oct 2009
                  • 345
                  #2303
                  Small spray of WD40 in the can will preserve them for some time. I used to build tiny rc boats as a kid by putting the prop directly on the shaft and gluing the motor to the bottom of the hull.
                  Hull looks great Dave...
                  Darrin
                    • 13948
                    #2304
                    Jörg
                    As an unschooled 'practical engineer, the only way I can get a mechanism to work properly is through the process of try something and alter the arrangement till the system works as intended. Elon Musk has made popular the work 'iteration'; his method of achieving flight-qualified hardware. Same thing -- build it, run it till something breaks, fix the broken part, run it again. Keep up the process till the desired performance is achieved and call it a day. I've run these cheap ass little can motors in the wet for years. When they ****-the-bed I just pop a new one in there. I got hundreds of these little things, left over from our Caswell days.
                      • 13948
                      #2305
                        • 13948
                        #2306
                          • 3736
                          #2307
                          Is the heat lamp to cook the oil paint to dry quicker?
                            • 13948
                            #2308
                            Heat promotes quicker 'drying'/curing of putties, fillers, primers, paints, and most weathering agents. Almost all of these mediums undergo a state change -- transitioning from liquid/paste/gel to solid -- as a consequence of polymerization: a chemical reaction takes place within the applied medium that causes the molecules of the medium to link up from single, to long chains. Epoxy, polyurethane, and other two-part mediums start the polymerization process once the base material is mixed with a 'hardener' or 'accelerator' (basically, a catalyst). Once mixed, a two-part medium creates heat, that process described as an exothermic reaction. That heat drives the mediums molecules to cross-link into a solid.
                            Hence the external heat I apply -- to quicken the cure of the mediums.
Name:	IMG_0554 - Copy.jpg
                            Those heat-lamps a testament to my unyielding impatience and refusal to sit patiently waiting for paint to dry; grass to grow; Lawer's to tell the truth; and to find an adequate number of female types to successfully do a man's job correctly (I'm looking at you, Secrete Service, Police, and Fire services).
                              • 13948
                              #2309
                              CAMERA BARGE
                              • bwi 971
                                • Jan 2015
                                • 940
                                #2310
                                Is that a coffin for the model-making craft?
                                grtz,
                                Bart, the poking SOB!
                                "Samuel Smiles"
