today's work
    • 1393
    #2956
    Hollow punch......https://www.amazon.de/-/en/Pieces-Ro.../dp/B07VBFQ9QW
    • biggsgolf
      • Jan 2020
      • 1036
      #2957
      Thanks guys!
        • 14014
        #2958
        Off subject, what are these?, size for 1:72 Skipjack? , where do I source them?
        Click image for larger version Name:	Image 13.jpg Views:	0 Size:	51.8 KB ID:	187643
          • biggsgolf
            • Jan 2020
            • 1036
            #2960
            Thank you Sir!
              • 14014
              #2961
                Somebody needs to build a Shark Hunter II and some DPVs to chase this.
                  • 14014
                  #2963
                    • 14014
                    #2964
                    Returned from SubFest... Back to Work! Fried one ESC, replaced leaking pushrod seals, and one leaking shaft seal had to be cored out and rebuilt. Not bad -- brought seven models to the event and they all got some water time.
                    ...And one stow-away ant (now Submarine Qualified). This little guy was aboard my Type-23 during all its runs at the event. Only found him when I cracked the WTC during post-mission checks.
                      A saboteur.
                        • 14014
                        #2966
                        A friend needs some clear hemisphere gun domes for his NAZI hydrofoil (What?). A vacuforming job. Been years since I did any of that type work and can't find the frames or plenums. Nuts! Got to make a plenum for this job, as well as a holding frame for the heated plastic sheet.
                        First, the plug/puck/form/pattern/mold/thewhateveritscalledthesedays... the item that will give form to the eventual parts.
                        As the items are small, a scrap piece of Lexan tube was pressed into service as the basic plenum structure. Caped with two WTC bulkheads I had in the spares bin. A hole in the side of the plenum will mate tightly with the household vacuum cleaner hose. Film at Eleven.
                          • 14014
                          #2967
                          A saboteur.
                          That ant has been dealt with...
                            He had such high hopes after moving that rubber tree plant.
                              • 14014
                              #2969
                                • 1393
                                #2970
                                Is this Super Lube silicone oil good? I've silicone grease but need something better....
