Daily submarine picture
This is a sticky topic.
    We used to have an engineer person(girl) from Russia that I used to translate the drawing that came with my Oscar from the Ukraine. She has moved on so I have to use Google Chrome. What a pity.
      The first relevant subs for the Norwegians were the HMS Talent, a T class, obviously, that then became the Zwardvis 1.Click image for larger version
Name:	boat_zwaardvis1_torquie_bay_1958 HMS Talent.jpg
ID:	83530Click image for larger version
Name:	boat_zwaardvis1_aft_deck_1956 HMS Talent.jpg
ID:	83531Click image for larger version
ID:	83532Click image for larger version
Name:	HMS Talent rear zoom.jpg
        Then there is Zeeluee1(spelling). It started out as USS Hawkbill.Click image for larger version
Name:	zeeluee 1  USS Hawkbill.jpg
ID:	83547Click image for larger version
Name:	boat_zeeleeuw1 USS HAWKBILL 1.jpg
ID:	83548Click image for larger version
Name:	boat_zeeleeuw1_USS Hawkbill.jpg
ID:	83549Click image for larger version
        • modelnut
          • Jun 2011
          • 140
          #1489
Name:	Two docked.jpg
          I wonder how long they were at sea to get that weathered.
          - Leelan
            Its amazing what salt water can do. We have steel forms lining some of our seawalls. You can just kick them and once proud strong steel just crumbles into giblets.
              It's the perfect electrolyte! And all that corrosion could have been prevented by an anode.
ID:	83556Click image for larger version
ID:	83557Click image for larger version
ID:	83558Click image for larger version
                  It doesnt take long for anything metal to oxidise around here. It doesnt even have to be in the water. I had my stainless steel grill on the dock and after the non stainless parts, like the steel on the castors for the wheels or internal brackets and whatnot actually disintigrated after less than two years and the rust spread to the stainless. I could have put a zincplate and wired it to all the nuts and bolts of all the dissimular metals but thats a little much. I do use zinc in the keels of my aluminium boats and use to zinc chromate the aluminium inside the hull, but now I just buy the aluminium sheets already annodised. It saves a few steps, but I havent splashed any new boats yet to see if it makes any differance. I was thinking the weathering is caused by oxidation which means air is the main catalyst, so it indicates a long time above the surface, in the weather, and that only happens when in port, since they dip as soon as they clear the main ship channel buoys and stay down till they get close to port. A little experiment for those who live by or on the sea, Take a strait pin and put it underwater for four or five days and it will remain shiney silver. Take another and just get it wet and put it on a plastic plate. Next morning the one on the plate will have rusted and leave a platina on the plastic. BTW this is a good way to give a model a real platina look if you have the patience. I also use sea water on display models for weathered effects. You can get the same effect with regular water if you put salt in it. You just immerse the model and let it air dry. It works best on flat finishes, and is good for armor and aircraft or ships as well.
                    So, your saying take the hull of your model sub, immerse it in salt water and let it air dry. After the weathering process is finished, should we then clean the hull of Salt residue or will it matter to the plastic or GRP?
ID:	83565Click image for larger version
Name:	Launch closer.jpg
ID:	83566Click image for larger version
Name:	Norwegian sub armatures.jpg
                        air dry after imersion, the salt residue may be built up more in some places and be somewhat crusty, if you use tap water that has been salted. You get a more even effect with the sea water. If there is too much build up in an area that you dont want, I use a dry flat brush and dust it off. The plastic is covered by the paint on the exterior and wont be effected. Plastic's worst problem is UV breakdown not so much as salt. The inside of the hull, may be a different matter, If its a RC model then I think the interior salt would be detromental to say the least. I think with a working model, I would just Paint the weathering with liquitex acrylac and matt clear. You figgure if your running the boat in the pool or lake, all that salt will be gone soon as you splash. I had a diorama that sat in a hobby store window for 4 or 5 years of an unpainted "Black Magic" M-4 Sherman, molded in OD and the morning sun had bleached everything on the window side. Looked real on the faded side, except fot the krackled decals
                        • NavyICman
                          • Jun 2010
                          • 60
                          #1497
                          Greenman,
                          You said in an earlier post "The first relevant subs for the Norwegians were the HMS Talent, a T class, obviously, that then became the Zwardvis 1." I believe you meant the Dutch. the Norwegians first had the Kobben from 1909 to about 1933. It was re-named the A-1 sometime around 1913. They never had a T class, They had 2 ex-brit boats (P41 and HMS Varne) during WWII, The Brits sold them 4 V class submarines after WWII, and they operated 3 Type VII's that were war prizes for several years. The most notable one was U-995 now on display in Laboe. Of an interesting note. The Norwegians have a cabin on an island out in the Fjord that their submarine base near Bergen sits on. They call it the periscope hut, great place to go party. They had ripped the wardroom areas out of one of the U boats, the wardroom area out of one of the V-boats, and a wardroom out of one of the Kobben class 205's that were operated well into 2000's and put them in there. So much history and nostalgia there, plaques from all of the US boats that have visited, a working periscope, and 2 swim-out mines that form the benches for a table......Had a great time, don't remember leaving...or getting back to the boat!
                            Yep, your right , I have trouble with my "N" words, you know , the Netherlands and Norwegian. I knew it was one of them for sure.
                            • NavyICman
                              • Jun 2010
                              • 60
                              #1499
                              No problem, I have always wanted to do a Walrus, so I knew all the pictures......I just got back from being in Norway a couple of months ago, learned almost all that info while being entertained at the periscope hut.
                              Tim
                                Your having too much fun.
