    • 1628
    #61
    I am going to use Prop from Danny, did not know Bob still sells them
ID:	174975Nice brass prop and shaft.
      • Jan 2020
      • 1028
      #62
      Printing and affixing Hull Tabs Click image for larger version
        • 13937
        #63
        Would it kill you to simply bend some .030" sheet styrene to the proper radius. Jeeez!
        This complexity warship HAS TO STOP!
ID:	174995 Click image for larger version
ID:	174996 Click image for larger version
ID:	174997 Click image for larger version
ID:	174998 Click image for larger version
ID:	174999 Click image for larger version
        And tighten up those limber holes at the bow. An artifact of kit tool design rendered them too tall.
ID:	175001 Click image for larger version
        Task Master
          • Jan 2020
          • 1028
          #64
          Thanks David, yes, Styrene just arrived!, lol! This look better? Click image for larger version
            • Jan 2020
            • 1028
            #65
            When I use Styrene on horizontal cut line how should I lay it down? Can I use Nitro Stan Putty?
              • 13937
              #66
              No!
              What the hell were you thinking?
              You thought making the corners within the too tall limber holes at their tops match the form of the corners at the bottom would fix these awful sphincter looking holes???
              Damnit!
              Rebuild with CA-baking soda grout within the holes top edge to reduce their height. Fine-tune the holes with files, sanding sticks, sandpaper twists of #240 sandpaper and god-knows-what to get them to proper shape.
ID:	175007 Click image for larger version
ID:	175008 Click image for larger version
ID:	175009 Click image for larger version
ID:	175013 Click image for larger version
ID:	175014 Click image for larger version
ID:	175015 Click image for larger version
ID:	175016 Click image for larger version
              Oh! Forgot to add these shots to show how to induce a tight radius into strip stock using a pinch-stick. File this trick away for future use. You're welcome!
ID:	175018 Click image for larger version
ID:	175019 Click image for larger version
              You people!
                • Jan 2020
                • 1028
                #67
                HAHAHA! Yeah, some people are hard to teach! (me)
                  • 13937
                  #68
                  You're a good sport.
                    • 3664
                    #69
                    How small should the limber holes be, L x H?
                      • 1628
                      #70
                      No!
                      Damnit!
                      You people!
                      Talk about anal.
                        • 13937
                        #71
                        Same as the extreme forward limber hole.
                          • 1628
                          #72
                          Dave,
                          did you add any grates on the bottom of your XXIII? I didn’t notice in Georgia.
                            • 13937
                            #73
                            Originally posted by Das Boot
                            Dave,
                            Nope. Just simple, no sweat, open flood-drain holes.
ID:	175035 Click image for larger version
ID:	175036 Click image for larger version
Name:	DSCF4664 - Copy.jpg
ID:	175037 Click image for larger version
ID:	175038 Click image for larger version
Name:	DSCF4667 - Copy.jpg
ID:	175039 Click image for larger version
ID:	175040 Click image for larger version
Name:	DSCF4652 - Copy.jpg
ID:	175041 Click image for larger version
                              • 1628
                              #74
                              Groovy. Easy Peasy.
                                • 3664
                                #75
                                Looks like it's 3D printed in resin. Click image for larger version
