1/144 Nautilus Typhoon 3d printed
  • indy1010
    • Aug 2022
    • 29
    #31
    I'm back after a 3d printer breakdown and a lot of putty work on the hull to align the upper part and the lower part.
    I will be able to move on to painting the hull​
Name:	20221216_165433 (Copier).jpg
Name:	20221216_165459 (Copier).jpg
Name:	20221216_165539 (Copier).jpg
    Frank
    (a belgian submariner)
      • 1777
      #32
      Love it! Great work so far!
      • indy1010
        • Aug 2022
        • 29
        #33
        printing of 2 parts for the locking system of the hull by magnets​
Name:	20230104_140103 (Copier).jpg
Name:	20230104_141912 (Copier).jpg
        Frank
        • indy1010
          • Aug 2022
          • 29
          #34
          Modification of one of the wtc supports which is smaller than the others (I don't know why).
          Creation of parts with the 3d printer and replacement​
          The smaller support in the lower hull
Name:	20230108_161916 (Copier).jpg
          gluing the new part​
Name:	20230108_173505 (Copier).jpg
          old part cutting​
Name:	20230120_112403 (Copier).jpg
          same operation on the upper part of the hull​
Name:	20230120_113748 (Copier).jpg
Name:	20230120_113951 (Copier).jpg
          Frank
          • indy1010
            • Aug 2022
            • 29
            #35
            ...and with his painting.
            It still lacks the markings and the matte protective varnish.​
            In reality the red paint is not as clear as in the photos. I used the same brand and reference as Bob in his video(Liquitex Professional Spray Paint - 12oz/400ml, Cadmium Red Medium Hue ref 0151):​
            This is an overview of the 3D files available for purchase from the Nautilus Drydocks. The video highlights assembly of the hull and linkages. NOTE: This is ...
Name:	20230122_122643 (Copier).jpg
Name:	20230122_122654 (Copier).jpg
            Frank
              • Oct 2017
              • 721
              #36
              Well done! Are you going to apply wheathering as well? Will it have bow thrusters, too?
              Jörg
              • indy1010
                • Aug 2022
                • 29
                #37
                Hi,
                it will not have bow thrusters.
                I'm not a fan of wheathering and I have to say that painting was a difficult step for me, it's not my favorite thing.​
                can someone tell me what these white lines parallel to the water are for​ ?
                Frank
                  • Oct 2017
                  • 721
                  #38
                  Construction waterline
                  • indy1010
                    • Aug 2022
                    • 29
                    #39
                    With construction waterline
Name:	20230205_142604 (Copier).jpg
Name:	20230205_142636 (Copier).jpg
                    Frank
                      • 1796
                      #40
                      indy1010,
                      Nice job! I really like the looks of the Typhoon. Keep us posted on well it does on the sea trials!
                      "Firemen can stand the heat."
                      • indy1010
                        • Aug 2022
                        • 29
                        #41
                        Hi,
                        I have a question for those who have printed endcaps for their wtc:
                        In the print settings, do you set the infill to 100%?
                        I find that by putting 100% the weight of the caps is high.
                        THANKS​
                        Frank
                          • 1796
                          #42
                          Originally posted by indy1010
                          Hi,
                          THANKS​
                          indy1010,
                          I have always used 100% infill on my WTC end caps. It's my opinion that going with 100% will slow down any water penetration (if there is any!) I have run water tests to see how long it takes for water to penetrate at different infill settings. I found 100% is for sure the best. With that being said I still coat the inside of my caps with a two part resin to add that extra seal against water penetration.
                          • indy1010
                            • Aug 2022
                            • 29
                            #43
                            Ok Rob, i will use 100% infill.
                            i was wondering if i painted the cap, wouldn't that make the cap watertight​ ?
                            Frank
                            • neitosub
                              • Nov 2021
                              • 129
                              #44
                              Yes if you spray paint the printed cap with a few coats it will be watertight. I do this on my endcaps all the time.
                              Nate
                              • indy1010
                                • Aug 2022
                                • 29
                                #45
                                thanks Nate,
                                I printed a test cap and I will try.
                                I have a wtc with an id=84mm. I bought o-rings with an od=84mm.
                                Unfortunately it's too big as a joint.
                                I will therefore have to wait until I have received the other o-rings to test the cap.​
                                Frank
