1/144 Nautilus Typhoon 3d printed
  • indy1010
    I started working on the ballast.
    It will be a 1 liter piston tank. I will be using a NEMA17 stepper motor.
    It will be controlled by an ARDUINO UNO
    I started making the piston with 2 o-rings. Problem, either the water passed or it was impossible to slide the piston.
    So I printed a new piston for hydraulic seal.​
    the piston
Name:	20230408_141456 (Copier).jpg
    The seal
Name:	20230408_141423 (Copier).jpg
    I printed a piece of motor support and limit switch support​
Name:	20230408_141433 (Copier).jpg
Name:	20230408_141449 (Copier).jpg
Name:	20230408_143125 (Copier).jpg
    and the closing plug with the water intake​
Name:	20230408_141617 (Copier).jpg
  • indy1010
    Well,
    I tested a cap with a coat of primer, a coat of paint and a coat of varnish.
    Cap printed with 20% infill.
    I mounted it on the wtc and put an hour in the water. All went well. Not the slightest trace of moisture inside the tube.​
  • reddevil
    By the way: Any one knows the distance between shafts in the motor mount in ENGEL's THYPOON?
  • indy1010
    thanks Nate,
    I printed a test cap and I will try.
    I have a wtc with an id=84mm. I bought o-rings with an od=84mm.
    Unfortunately it's too big as a joint.
    I will therefore have to wait until I have received the other o-rings to test the cap.​
  • neitosub
    Yes if you spray paint the printed cap with a few coats it will be watertight. I do this on my endcaps all the time.
    Nate
  • indy1010
    Ok Rob, i will use 100% infill.
    i was wondering if i painted the cap, wouldn't that make the cap watertight​ ?
    Originally posted by indy1010
    Hi,
    I have a question for those who have printed endcaps for their wtc:
    In the print settings, do you set the infill to 100%?
    I find that by putting 100% the weight of the caps is high.
    THANKS​
    indy1010,
    I have always used 100% infill on my WTC end caps. It's my opinion that going with 100% will slow down any water penetration (if there is any!) I have run water tests to see how long it takes for water to penetrate at different infill settings. I found 100% is for sure the best. With that being said I still coat the inside of my caps with a two part resin to add that extra seal against water penetration.
    "Firemen can stand the heat."
  • indy1010
    Hi,
    THANKS​
    indy1010,
    Nice job! I really like the looks of the Typhoon. Keep us posted on well it does on the sea trials!
  • indy1010
    With construction waterline
Name:	20230205_142604 (Copier).jpg
Name:	20230205_142636 (Copier).jpg
    Construction waterline
  • indy1010
    Hi,
    it will not have bow thrusters.
    I'm not a fan of wheathering and I have to say that painting was a difficult step for me, it's not my favorite thing.​
    can someone tell me what these white lines parallel to the water are for​ ?
    Well done! Are you going to apply wheathering as well? Will it have bow thrusters, too?
    Jörg
  • indy1010
    ...and with his painting.
    It still lacks the markings and the matte protective varnish.​
    In reality the red paint is not as clear as in the photos. I used the same brand and reference as Bob in his video(Liquitex Professional Spray Paint - 12oz/400ml, Cadmium Red Medium Hue ref 0151):​
Name:	20230122_122643 (Copier).jpg
Name:	20230122_122654 (Copier).jpg
  • indy1010
    Modification of one of the wtc supports which is smaller than the others (I don't know why).
    Creation of parts with the 3d printer and replacement​
    The smaller support in the lower hull
Name:	20230108_161916 (Copier).jpg
    gluing the new part​
Name:	20230108_173505 (Copier).jpg
    old part cutting​
Name:	20230120_112403 (Copier).jpg
    same operation on the upper part of the hull​
Name:	20230120_113748 (Copier).jpg
Name:	20230120_113951 (Copier).jpg
