1/144 Nautilus Typhoon 3d printed
I'm back after a 3d printer breakdown and a lot of putty work on the hull to align the upper part and the lower part.
I will be able to move on to painting the hull
Thanks Rob,
I must say that I take great pleasure in making this submarine. For the moment, I am only at the model part. It is not always obvious.
I realize that with large pieces, there are distortions in the print. They have to be recovered with mastic.Leave a comment:
Hi Frank,lower part of the hull with primer paint
Small modification compared to the assembly diagram: the front of the hull (part 8) has been fixed to the lower part of the hull and not the upper part in order to avoid working with magnet connections for the bow planes controls .
Your Typhoon is very impressive. I have been following your build and watching the progression you have made. I am impressed with your bow plane linkage, and if I am looking at them correctly, they will not only operate as a fully functional bow plane, but recess back into the hull when not in use?
Keep up the great work! And keep posting up your photos.
Small modification compared to the assembly diagram: the front of the hull (part 8) has been fixed to the lower part of the hull and not the upper part in order to avoid working with magnet connections for the bow planes controls .Last edited by indy1010; 11-23-2022, 10:33 AM.Leave a comment:
yes 40mm / M2 / 7 blades
you can find the right propeller here :
The Nautilus Drydock is proud to stock a selection of high quality brass propellers from Raboesch. As much as I'd love to offer the entire expansive selection that they offer, I've elected to carry only the most commonly asked for propellers. If you have a specific requirement, feel free to let me know what you're after. Bear in mind, however, that Raboesch has a minimum order value that may significantly affect your price for orders of one or two of a specific size. I currently offer propellers for the following models in the following sizes: Skipjack 1:72 scale: 55mm diameter, Right turning, 5 blade, M4 threads: $22 each US Gato Class in 1:72 scale: 35mm diameter, left/right hand, four blade, M3 threads: $38/set of two propellers German Type VII in 1:48 scale: 35mm diameter, left/right hand, three blade, M4 threads: $34/set of two propellers German Type XXI in 1:48 scale: 45mm diameter, left/right hand, three blade, M4 threads: $40/set of two propellers German Type XXIII in 1:35 scale: 50mm diameter, right hand turn, three blade, M4 threads: $21 each US Sturgeon Class in 1:96 scale: 50mm diameter, right hand turn, 7 blades, M4 threads: $34 each USS Nautilus SSN 571 in 1:96 scale: 20mm diameter, right/left hand turn, 5 blades, M3 threads: $40/set Russian Typhoon in 1:144 SCALE: 40mm diameter, right/left hand turn, 7 blades, M4 threads: $70/set 1/96 US Los Angeles Class ringed propeller: $35 each (sintered nylon, not brass) 1/96 Russian Alfa: $40 each - 3D printed steel constructionLeave a comment:
Hi Gantu,
I'm sorry but I don't speak English. I use google translator and it doesn't know "cortnozzels" or "props2". So I don't understand the question.Leave a comment:
👍 1Leave a comment:
Are you sure? The limber holes do not align.id rather say that hole section is warpedLeave a comment:
