Announcement
No announcement yet.
1/144 Nautilus Typhoon 3d printed
small printing retraction problem. I will print a little triangular piece and glue it.and after put a little putty
end of assembly of the rear linkage.I also painted the back of the typhoon because I don't see how to do it once diving planes are mounted.
Parts 1 and 2: sandpaper 240, spray putty and finish with wet sanding (600 sandpaper)
Then, I had to make changes to parts 2 and 3 so that they fit together.
in the red circle, 5mm cut
piece cut here too
Hi Frank,
Your Typhoon is looking great! Enjoyed seeing your photos! Well done!
Originally posted by indy1010 View Postsmall printing problem. On the parts hull 5b, hull 6b and hull 7b, I have the circled part that detaches from the hull. I will have to glue them.
As I recall on my first build of the Typhoon using Nautilus Drydocks files, I had a similar situation! I just cleaned up that area and reattached with a quality medium CA. Worked out well for me!
I wish I could have finished my Typhoon! I got about half way through the build and somehow (old age) lost my files. I really want to build the Typhoon, so I got a hold of Bob, and he sent me another set of files at no charge! Nautilus Drydocks (Bob & Jason) are really great when it comes to quality parts and go out of their way to help you with your submarine builds!
Keep printing away with your Typhoon, and do not get discouraged with the process!
Hull 7A part
it will remain hull 7B and hull 8
It takes a long time to print.
I am on my third spool of 1kg of PLA
Thank's.
actually, I look at the polyester fillers used in car bodywork (two components with hardener)
I had a little sagging too.
Bondo is a brand that is produced by 3M. Could be that it's only sold under that name in the US, but of course you can get 3M 2k polyester putty in Europe as well:
Any other good qiality 2k polyester putty sold in your local hardware store or even better professional paint shop will do the job, too.
Here's a little motivation for you! Prints pretty well, I had a little sagging that I never could figure out, but thats what bondo is for....
- Likes 1
Originally posted by indy1010 View PostHello Rob, when I will be further in the project I will have questions for you because I also want to print my wtc caps like you.
I started to learn how to use freecad. This is not obvious !!
When you are ready, I will help all I can! You will find a great deal of help on this forum and from some REAL masters at sub building!
