    • 13879
    #166
    Wet side to the right.
    Click image for larger version  Name:	035.JPG Views:	0 Size:	89.3 KB ID:	149724Click image for larger version  Name:	025.JPG Views:	0 Size:	83.5 KB ID:	149725Click image for larger version  Name:	027.JPG Views:	0 Size:	79.0 KB ID:	149726
      • Jan 2020
      • 1028
      #167
      David, how does the opposing gear shaft adhere to the endcap, I am confused
        • 13879
        #168
        The opposing gear is free to slide out and is kept in place by the rigidity of the running gear - the shaft and universal (flexible tube) elements. The ahead and astern loads are absorbed by the submarines strut bearings (the GATO) or stern tubes (the OSCAR). Neither the drive or opposing gear are subjected to thrust loads.
          • 3636
          #169
          As the bladder is filled air inside the wtc would become pressurized and it would leak pass through a normally placed seal. Placing it inboard would prevent that but leaves you vulnerable to leaks as you go deeper. Maybe install 2 seals placed back to back or swap it out with O-ring.
            • Jan 2020
            • 1028
            #170
            Thanks guys
              • Jan 2020
              • 1028
              #171
              Both my 1:96 Blueback & 1:144 Kilo are ready for pool testing next week. Next project will be a 1:144 Soryu Conversion, then a 3D Printed 1:144 Akula.
                • Jan 2020
                • 1028
                #172
                Ok, best Submarine Pool Trials I have ever experienced since entering this Hobby February 2020. Both my 1:96 Blueback and 1:144 Kilo were exceptional. Great surface, submerged trims and full functionality of Rudders, Dive Planes and Stern Planes. First time I could run my Blueback at low surface throttle and turn well within my pools 14’ width.
                Weather permitting I will shoot some video and post. My wifes comment was “now you don’t need another one!”, yeah right…….
                  • 13879
                  #173
                  No, no... NO!
                  The correct answer to SWMBO is ALWAYS: "Yes, dear".
                  Hard-stop.
                  Don't say another word.
                  Back away carefully as you frantically seek a route of escape.
                    • Jan 2020
                    • 1028
                    #174
                    Hahahahaha, you are correct sir, I acted like I did not hear her as I walked away!
                      • Jan 2020
                      • 1028
                      #175
                      Videos of 1:144 Kilo and 1:96 Blueback
                        • 3636
                        #176
                        Love the red stern planes, breaks up the monotony.
