    • Jan 2020
    • 731
    #76
    Suggestions on how I should cut off excess stern planes rod? Should I use dremel cutting wheel, Snips, jewellers hand saw? I am afraid to blow out the interior mechanics!
    • reddevil
      • Jun 2009
      • 346
      #77
      Using the dremel may generate too much heat and melt the plastic. May be a hand saw?
        • Jan 2020
        • 731
        #78
        Thats what I was thinking as well on the Dremel
          • 2749
          #79
          If you used thin brass rods I think the Dremel will be able to cut it before you reach the plastic's melting point. If you want you could immerse the part in water, the water will act as a heat sink.
            • 2749
            #80
            Speaking of cutting in water, check this out
              • Jan 2020
              • 731
              #81
              Kewl stuff!
                • Jan 2020
                • 731
                #82
                Anyone know is the Kilo life raft is red & white or orange & white?
                  • 2749
                  #83
                  Orange and white
                    • Jan 2020
                    • 731
                    #84
                    Thanks so much!
                      • Jan 2020
                      • 731
                      #85
                        • Jan 2020
                        • 731
                        #86
                        Using my Jewelers hand saw the rods were trimmed perfectly
                          • 2749
                          #87
                          What diameter rods did you use?
                            • Jan 2020
                            • 731
                            #88
                            I used all 1.57 mm rods, 2 mm was too thick and less then 1.57 mm had too much play.
                              • Jan 2020
                              • 731
                              #89
                              Magnets in stern, bow and sail to attach, no screws
                                • Jan 2020
                                • 731
                                #90
                                Dive planes rod and magnet
