jims Tyhpoon TK-208 build
  • deepseadiver
    • 296
    All the Engel Typhoon hulls have that gap at the bow, think it's a fault in the tooling.
    Most builders fill it in, then extend the anechoic tile lines. Some have used an epoxy putty rather than polyester car filler. Epoxy putty is much tougher and resistant to chipping.
    Subculture thank you for that advice yes I noticed other builders are having that problem in the front.
    I wanted to mention that I had a large gap of 1/4 inch in the front at first I was told by others this can be helped . I place in my hold down screw then placed a 4x4 piece of wood underneath the front with foam padding. Then I put padding over the top and place a 25 pound weight on top, which then close up the gap almost all the way.
    Then i place a space heater In front of the nose let it cool 3 times in a row, took off the weight and most of the gap is gone . Now the hold down screw tightens down even more.
    I Like your advise just need to fill in the rest of the gap as you mentioned using epoxy, since it wont chip as easily!
    your information is very helpful
    Jim
    • deepseadiver
      • 296
      here are some lead weight shot In the keel I used plastic wrap because I did not have any wax paper seem to work just fine and it came off the resin once it cured plastic wrap peeled right off. Now I can have all the weight required In the keel and easy to remove if I need to during trimming. Once I know the correct weight I will glue them in. What do you think ?
      • deepseadiver
        • 296
        more pictures
        • deepseadiver
          • 296
          once I get them out I will trim off the excess resin
          • deepseadiver
            • 296
            Here's what I have done so far to the electronic box I have the holes drilled a custom lip I placed over them which the groove for the rubber gasket goes into them. Next I'm going to install SS bolts, epoxy them in place all 44 of them .
            Comments welcomed !
              • 12317
              No pictures.
              • deepseadiver
                • 296
                trimmed out the top piece of the submarine conning towers opening
                • deepseadiver
                  • 296
                  the bolts that all got glued in what a job getting them all glued in .
                  • deepseadiver
                    • 296
                    bolts are secure and the 4mm rubber cord gasket is installed
                    • deepseadiver
                      • 296
                      Oh boy that was a big job making that custom WTC with see through windows, for the electronics it was well worth it indeed (Thanks Bob for advising me to do it.)
                        • 1777
                        Great work so far, Jim! Are you going to swap out the acorn nuts for the main section for wing nuts, or just use the supplied ones?
                        • deepseadiver
                          • 296
                          Hi bob,
                          good question I was going to ask you that same question you read my mind. After looking at your typhoon video, I see the switch is in the middle so should I place the acorn on the ends and use the wing nuts for the middle section? plus Engel uses a magnetic switch to turn things on and off should I use it?
                            • 1777
                            You definitely need a switch of some kind. The magnetic ones work okay, but I've fallen in love with my remote switches. 15A capacity, which should be fine for the Engel boat. No need to swipe a specific spot. Just click the fob on and click the fob off.
                            I'd replace all the acorns with wing nuts, personally. No need for tools, easy to get on and off, and easy to feel the correct amount of pressure when you're tightening them up.
                            • deepseadiver
                              • 296
                              Hi Bob,
                              thank you good advice I appreciate that very much. can you sell me a remote switch fob like what you used or direct me were to purchase one.. I saw you turn on a submarine, electronics when you were showing how to trim a submarine, in a pool, on YouTube . It was a excellent video by the way . I learned some stuff from it .
                              I think it's a great way turning on the power inside the submarine, by a remote turn on. I can use Engels magnet switch for other things in the future.
                              Jim
                              • deepseadiver
                                • 296
                                #30
                                can anyone direct me towards getting some help. I need a decal made otherwise I may just have to hand paint it.
                                what I need is a decal of some sort that goes in front of the conning tower on this typhoon submarine its a Russian logo needs to be about 1' 1/4 long 1' wide can anyone help
