Apply filler, sand, apply cloth/epoxy, sand, apply epoxy, sand, apply glazing putty, sand, apply glazing putty again, sand. That's what I've been doing the last few days.
The filler and epoxy has eliminated the ridge between sections and now as expected have to deal with ridge between the epoxy and polystyrene. These differences are not noticeable in the pictures but they are there. Smoothing this out is accomplished with glazing putty and sanding and feathering. Once sanding is done I expect to see bands of glazing on either side of the hull seam.
The gaps in the corners where the upper and lower sections meet were also eliminated. See previous pictures.
Arrows are about where most of the glazing putty will end up.
More sanding to do here. Two of those openings were covered up, will open those up again.
Anxious to get this over with and get on to other more interesting mechanical bits.
